Category
Top » Problem Solving » Clearing Paper Jams » Staple Finisher-G1/Booklet Finisher-G1 (Optional)
Category Top
Clearing Paper Jams
Locations of Paper Jams
Main Unit
Paper Sources
Paper Drawer
Cassette Feeding Unit-AF1 (Optional)
Paper Deck Unit-B2 (Optional)
Feeder
Inside the Top Cover
Buffer Pass Unit-H1
External 2/3 Hole Puncher-B2
Inside the Front Cover
Saddle Stitcher Unit
Inner Finisher-D1 (Optional)
When the Inner 2/3 Hole Puncher-A1 Is Not Attached
When the Inner 2/3 Hole Puncher-A1 Is Attached
Inner 2Way Tray-H1 (Optional)
Reducing the Frequency of Paper Jams
Clearing Staple Jams (For Optional Products)
Locations of Staple Jams
Saddle Stitcher Unit of the Booklet Finisher-G1
Inner Finisher-D1
If Memory Becomes Full during Scanning
Printer/Fax Driver Troubleshooting
Service Call Message
List of Error Messages
General
Fax
Scan and Send
Scan and Store/Access Stored Files
Quick Menu
Printer
Network
MEAP
User Setting Information Management
List of Error Codes without Messages
Collapse all|Expand all
If a paper jam occurs inside the finisher or puncher, a screen prompting you to remove the jammed paper appears on the touch panel display. Check the location of the paper jam, and follow the procedure described below, while referring to the directions that appear on the touch panel display, to remove the jammed paper.
The Staple Finisher-G1, Booklet Finisher-G1, and Buffer Pass Unit-H1 are optional products.
