Paper Deck Unit-B2 is an optional product.
1. Press the release button.
2. Move the paper deck unit away from the main unit.
1. Hold down the green lever on the side of the paper deck unit.
2. Remove any jammed paper, while holding down the green lever.
Paper can also be jammed in the feeding slot on the side of the main unit. Remove any jammed paper from the feeding slot.
CAUTION |
When connecting the paper deck unit to main unit, be careful not to get your fingers caught, as this may result in personal injury.
1. Press the open button.
2. Open the paper deck unit.
The inside lifter automatically descends to the paper loading position.
If the machine is in the Sleep mode (the touch panel is not displayed, and only the main power indicator is lit), you may be unable to open the paper deck unit. In this case, press the control panel power switch to reactivate the machine, and then press the open button on the paper deck unit.
Look carefully, as jammed paper may be difficult to see.
CAUTION |
When closing the paper deck unit, be careful not to get your fingers caught, as this may result in personal injury.
The screen indicating the directions on how to clear the paper jam is displayed repeatedly until the paper jam is cleared.
