1. Lift the area indicated by the label on the output slot.
2. Remove any jammed paper that is visible.
If you cannot see any paper, check whether there is any jammed paper in the output area.
If a paper jam occurs when you are printing in the Staple mode, do not remove the output sheets that are waiting to be stapled. (Printing and stapling resume after you clear the paper jam.)
1. Open the top cover of the finisher.
2. Remove any jammed paper.
3. Close the top cover of the finisher.
CAUTION |
When closing the cover, be careful not to get your fingers caught, as this may result in personal injury.
The screen indicating the directions on how to clear the paper jam is displayed repeatedly until the paper jam is cleared.
