Service call message
It is an error state in which the printer cannot print.
Warning message
It is a warning state in which the printer can print, but some solution is required.
Error message
Mark
Description
<Auto Error Skip>
For a message with this mark, perform the following procedure according to the situation.
When you want to skip an error (error skip) and continue to print
If you want to cancel a job
If multiple warning states are occurring at the same time
Warning messages are displayed alternately.
If an error state and warning state are occurring at the same time
A warning message is not displayed.
If a toner-related message appears
On how to act if a toner-related message such as <Toner cartridge will soon reach end of lifetime.> or <1G Change toner cartridge recommended.> appears, see "Toner Cartridge Replacement."
"Load paper. "
Solution
Solve the problem following the instructions in "If a Service Error Is Displayed."
Solution
Follow the procedure in "If a Fixing Unit Error Is Displayed" in "The Message Indicator Is On", and then contact your local authorized Canon dealer.
Solution
Solution
Solution
Reduce the amount of the paper in Drawer 2.
Solution
Remove the paper in the output tray.
Solution
When the running of the MEAP application stops, the message disappears automatically. Wait until the message disappears.
Solution
Though printing is possible as is, logs such as the job histories cannot be recorded correctly. Contact your local authorized Canon dealer.
Solution
Although you can continue to print for a while, have ready a new waste toner container.
Solution
Clear the hard disk error on the POP3 server.
Solution
Check the error in detail using the Remote UI or Network Status Print.
Solution
Update the firmware.
Solution
Restart the printer. If the error message still appears after restarting this printer, contact your local authorized dealer.
Solution
Check the authentication server's certificate.
Solution
Change the password registered in the authentication server, and reset the IEEE802.1X authentication password.
Solution
Change IEEE802.1X authentication systems.
Solution
Check to see if the cable is disconnected.
Solution
Check the IEEE802.1X settings, and reconfigure them.
Solution 1
The certificate used for TLS authentication is not correct. Check the certificate, and reconfigure it.
Solution 2
If the printer's certificate is correct, check the authentication server's CA certificate.
Solution 1
Solution 2
Check the printer's and the authentication server's time settings.
Solution 1
Solution 2
Install the CA certificate in the printer.
Solution
Change the printer's IPv4 address and restart.
Solution 1
Press [
] ( Online) to cancel printing, and then print again. |
Solution 2
A problem may be occurring in the network you are using. Check the status of the network that you are using.
Solution
Perform a soft reset using the Reset menu, and then print again.
Solution
Enter the correct password.
Solution
Change the settings to permit printing.
Solution
Check the policy server's power supply and the status of this product, the policy server, and the network.
Solution 1
If a paper source is specified, press [
] ( Feeder Selection), and then set [Paper Source] to [Auto]. |
Solution 2
Press [
] ( Feeder Selection) to select another paper source. |
Solution 3
Load paper appropriate for the paper source.
Solution 4
Specify the following items.
[Standard Paper Size]
[Default Paper Type]
Solution 5
Press [
] ( Online), and then print from the currently selected paper source. However, this may result in deterioration in print quality. |
Solution 1
Press [
] ( Online) to continue printing. However, the data on each side is printed on two pages. |
Solution 2
Perform the following procedure.
Solution 1
Press [
] ( Online) to continue printing. In this case, the printer prints with the image quality level being lowered. |
Solution 2
Solution 1
Press [
] ( Online) to continue printing. However, the data may not be printed properly. |
Solution 2
Confirm the data to be printed, and then print again.
Solution
Solution 1
Press [
] ( Online) to cancel the job. Afterward, perform the following processes (decreasing the size of the PDF file), and then print again.Optimizing the PDF file
Dividing the PDF file into multiple files
Solution 2
Send the file again using one of the following methods.
Insert the SD card into the slot and send the file again.
Send the file directly from the USB memory device.
Solution
Press [
] ( Online) to cancel the job. If print job restrictions are set, only the data stored in a box can be printed. Store the data you want to print in a box. |
Solution
Solution 1
The printer is ready to print by pressing [
] ( Online), ignoring the print data. |
Solution 2
Delete unnecessary stored jobs.
Solution 1
Solution 2
Solution
Specify the correct box number.
Solution
Print your job again by entering the correct department ID and password.
Solution
Allow print jobs with unknown IDs from the Remote UI.
Solution
Solution
Replace the waste toner container with a new one.
Solution
Turn OFF the printer, remove the packing material (sheet) from inside the right cover, and then turn the printer back ON.
Solution
Specify the setting properly.
Solution
Load the paper in landscape orientation, and then print again.
Solution
Load the paper in portrait orientation, and then print again.
Solution
Set [Check Paper Size] to [Off], and then print again.
Solution
Load transparencies and print again.
Solution
Load paper appropriate for the print data and print again.
Solution
Remove the sealing tapes and set the toner cartridge in the correct position.
Solution
Close the cover firmly. If the printer is not online, press [
] ( Online). |
Solution
Solution
Solution
This printer cannot print the data. Press [
] ( Online) to cancel the job. |
Solution
Solution 1
Open the right cover and check if the fixing unit is installed.
Solution 2
Install the fixing unit again. If the message appears even after installing the fixing unit again, contact your local authorized Canon dealer for servicing.
Solution
Solution 1
Refill or load paper.
Solution 2
Press [
] ( Feeder Selection), and then select other paper source for the same paper size or larger paper size. |
Solution 1
Press [
] (Online ) to continue printing. However, the job with which an error has occurred is not printed. |
Solution 2
Solution 1
Press [
] ( Online) to continue printing. However, the overflowed data cannot be registered. |
Solution 2
Solution
Solution 1
Press [
] ( Online), and continue printing. However, the data that generated the error will not be printed correctly. |
Solution 2
If images such as Progressive JPEG are handled inside the XPS, convert them to TIFF or Baseline JPEG and then print.
Solution 1
Press [
] ( Online) to continue printing. However, the page with which an error is occurring is not printed. |
Solution 2
Solution 3
Solution 4
If [2-Sided Printing] is set to [On], specify [Off], and then print again.
Solution 5
Change the setting for [Halftones], and then print again.
Solution 1
Press [
] ( Online) to continue printing. However, the data with which an error is occurring is not printed properly. |
Solution 2
Solution 1
Press [
Solution 2
Solution
Solution
Remove the jammed paper and set the paper drawer and covers to the original position. If the printer is not online, press [
] ( Online). |
If paper jams occur at multiple areas at the same time, the areas appear in the display by rotation.
If you removed the jammed paper without opening any cover, be sure to open and close the front cover once, and then press [
] ( Online). |
Solution
Solution
Solution
Specify the print range correctly, and then print again.
Solution
Print the data again from the printer driver for LBP5480.
Solution 1
If [
] ( Online) is pressed, settings that do not use the SD card are activated. However, you cannot print with functions that use the SD card. |
Solution 2
Turn OFF the printer, and make sure that the SD card is inserted correctly.
Solution 3
Contact your local dealer for repairs.
Solution 1
Turn the printer OFF, wait for 10 seconds or longer, and then turn it ON again.
Solution 2
Run SD card quick format or standard format.
Solution 3
Solution 1
Load the paper of the size selected in the application (or the one specified by scaling factors).
Solution 2
Press [
] ( Online), and then print to the currently loaded paper forcibly. If you are using the multi-purpose tray, the setting for [MP Tray Paper Size] in the [Select Feeder] menu automatically changes to the paper size specified in the application. |
Solution
Solution
Specify the setting for [Paper Source] in the [Select Feeder] menu properly.
Solution
Load Letter size or A4 paper in the multi-purpose tray, and then press [
] ( Online). |
Solution 1
Press [
] ( Online) to continue printing from the next data. However, the page with which an error is occurring and its subsequent pages are not printed. |
Solution 2
Solution
Turn the power OFF, install the paper feeder properly, and then turn it ON again.
Solution
Turn the power OFF, install or remove the paper feeder, and then turn the printer ON again.
Solution
Turn the printer OFF, unplug the power plug from the AC power outlet and contact your local authorized Canon dealer for servicing.
Solution
Turn the power OFF, install the paper feeder for this printer, and then turn it ON again.
Solution
Check to make sure that the data that was input is normal, restart it and print again.
Solution 1
Press [
] ( Online) to cancel the job. Afterward, perform the following processes and then print again.Optimizing the XPS file
Dividing the XPS file into multiple files
Solution 2
Solution
Check the output result for missing text, and correct the data.
Solution
Check the output result for missing images, and correct the data.
Solution
Check the output result for missing pages, and correct the data.
Solution
Check the page range, and print again.
Solution
Contact your local dealer.
Solution
Change the images in the XPS file to TIFF or JPEG format and print again.
Solution
Cycle the power of the printer. If the message appears even after cycling the power of the printer, note down the message in the display, and contact your local authorized Canon dealer.
Solution
Solution
Solution
Solution
Solution
