Setting Restrictions for Print Jobs
You can use the Web browser (Remote UI) to set restrictions for print jobs.
When restrictions for print jobs are set, the effect will be as follows.
Type of job
Restriction
Printer Driver
Will be stored in a box.
Direct Print
Image File
Will not be displayed in the menu.*
PS/PDF
XPS
USB Direct Print
Cannot be output.
Utility Menu
There are no restrictions.
*The settings will be enabled after a hard reset or after the printer is restarted.
1
Start the Remote UI, and then log in as Administrator.
2
Click [Settings/Registration].
3
Select [Security] from the [Management Settings] menu.
4
Click [Management Settings].
5
Click [Edit...].
6
Enter the current password in [Current System Manager Password].
7
Set restrictions for print jobs.
(1)
Select the [Restrict Printer Jobs] check box.
(2)
Click [OK].
