The following consumables are provided for this printer. Purchase them at your local authorized Canon dealer.
Use the following table as rough guides to replace consumables. However, you may need the replacement earlier than the described lifetimes depending on the printer installation environment, paper size, or document type.
Consumables
Replacement Timing
Replacement Method
Canon GPR-45 H
Black Toner
Average yield: 12,000 sheets*1 *2
Canon GPR-45 Yellow Toner Canon GPR-45 Magenta Toner Canon GPR-45 Cyan Toner
Average yield: 6,400 sheets*1 *2
WASTE TONER BOX WT-723
Approximately 18,000 pages (when performing 1-sided printing on Letter size paper)
*1
The average yield is on the basis of "ISO/IEC 19798"* when printing Letter size paper with the default print density setting.
"ISO/IEC 19798" is the global standard related to "Method for the determination of toner cartridge yield for color printers and multi-function devices that contain printer components" issued by ISO (International Organization for Standardization).
*2
When the toner cartridge needs to be replaced soon, the following messages will appear in the control panel.
About replacement toner cartridges or waste toner containers
For optimum print quality, using Canon genuine toner cartridges or waste toner containers is recommended.
Model Name
Supported Canon Genuine Toner Cartridge
LBP5480
Canon GPR-45 H Black Toner
Model Name
Supported Canon Genuine Waste Toner Container
LBP5480
Be careful of counterfeit toner cartridges or waste toner containers.
Please be aware that there are counterfeit Canon toner cartridges and waste toner containers in the marketplace.
Use of counterfeit toner cartridge or waste toner container may result in poor print quality or machine performance.
Canon is not responsible for any malfunction, accident or damage caused by the use of counterfeit toner cartridge or waste toner container.
Toner, Toner Cartridge and Waste Toner Container Availability
Toner cartridge and waste toner container for this machine will be available for at least seven (7) years (or any such longer period as required by applicable laws) after production of this machine model has been discontinued.
