: Available
: Unavailable|
Paper Type
Setting for [Paper Type]*1
Paper Size
Paper Source
2-sided Printing*2
Multi-purpose Tray
Drawer 1
Drawer 2 (optional)
Plain paper *3 (16 to 19.7 lb Bond (60 to 74 g/m²))
[Plain L] *5*6
[Plain L2] *5 |
A4
B5
A5
*4 |
*4 |
A6 *4
Legal
Letter
Executive
Statement *4
Foolscap
16K
Custom size paper
*11*18 |
*12*17 |
*15*18 |
Plain paper *3 (18.6 to 27.9 lb Bond (70 to 105 g/m²))
[Plain] (Default) *6*7
[Rough] *10 |
A4
B5
A5
*4 |
*4 |
A6 *4
Legal
Letter
Executive
Statement *4
Foolscap
16K
Custom size paper
*11*18 |
*12*17 |
*15*18 |
Heavy paper (26.6 lb Bond to 44.4 lb Cover (100 to 120 g/m²))
[Heavy 1] *7*8
A4
B5
A5
*4 |
*4 |
A6*4
Legal
Letter
Executive
Statement *4
Foolscap
16K
Custom size paper
*11*18 |
*12*17 |
*15*18 |
Heavy paper (30.6 lb Bond to 60.3 lb Cover (115 to 163 g/m²))
[Heavy 2] *8
A4
B5
A5
*4 |
*4 |
A6*4
Legal
Letter
Executive
Statement *4
Foolscap
16K
Custom size paper
*11*18 |
*12*17 |
*15*18 |
Heavy paper (60.6 to 79.9 lb Cover (164 to 216 g/m²))
[Heavy 3]
A4
*16 |
B5
*16 |
A5
*16 |
A6
Legal
*16 |
Letter
*16 |
Executive
*16 |
Statement
Foolscap
*16 |
16K
*16 |
Custom size paper
*11 |
*16 |
Transparency
[Transparency]
A4
Letter
Label
[Labels]
A4
B5
A5
A6*4
Legal
Letter
Executive
Statement *4
Foolscap
16K
Custom size paper
*11 |
Index Card*19
[Heavy 2]
Index Card
Envelope
[Envelope]
Envelope Monarch
Envelope No.10
Envelope DL
Envelope ISO-C5
*1
The setting is located in the [Paper Source] tab in the printer driver. If you print from DOS, UNIX, or other operating system, specify a paper type in [Default Paper Type] in the control panel.
*2
2-sided printing supports paper with a weight of 16 lb Bond to 60.3 lb Cover (60 to 163 g/m²).
*3
Recycled paper can be also used.
*4
The paper can be loaded only in landscape orientation (when the long edges of the paper are parallel to the front side of the printer).
*5
If 16 lb Bond (60 g/m²) paper is set to [Plain L] and printed and the print result output paper is curled (the printed side is curved), set it to [Plain L2].
*6
When printing 18.6 to 19.7 lb Bond (70 to 74 g/m²) paper, it is all right to set it to either [Plain] or [Plain L]. *9
*7
When printing 26.6 to 27.9 lb Bond (100 to 105 g/m²) paper, it is all right to set it to either [Plain] or [Heavy 1]. *9
*8
When printing 30.6 lb Bond to 44.4 lb Cover (115 to 120 g/m²) paper, it is all right to set it to either [Heavy 1] or [Heavy 2]. *9
*9
If either is set and the following problems occur, set it to the other setting and then print.
The output paper is curled.
After-images appear on the parts that are not printed.
The toner does not fix well and the printing is faded.
*10
Specify [Rough] for this item when a paper jam occurs or when you want to improve the fixation on printing coarse paper (19.9 to 23.9 lb Bond (75 to 90 g/m²)) with [Plain] selected.
*11
You can load paper of the following custom paper sizes.
In case of portrait orientation (only when the UFR II printer driver is used): Short edges 5.00 to 8.50 in. (127.0 to 215.9 mm); Long edges 5.00 to 8.50 in. (127.0 to 215.9 mm)
In case of landscape orientation: Short edges 3.00 to 8.50 in. (76.2 to 215.9 mm); Long edges 5.00 to 14.00 in. (127.0 to 355.6 mm)
*12
In case of portrait orientation (only when the UFR II printer driver is used): Short edges 5.83 to 8.50 in. (148.0 to 215.9 mm); Long edges 5.83 to 8.50 in. (148.0 to 215.9 mm)
In case of landscape orientation: Short edges 4.00 to 8.50 in. (101.6 to 215.9 mm) *13; Long edges 5.83 to 11.69 in. (148.0 to 297.0 mm) *14
*13
When width is 8.50 in. (215.9 mm), max length is 11.00 in. (279.4 mm).
*14
When length is 11.69 in. (297.0 mm), max width is 8.27 in. (210.0 mm).
*15
In case of portrait orientation (only when the UFR II printer driver is used): Short edges 8.27 to 8.50 in. (210.0 to 215.9 mm); Long edges 8.27 to 8.50 in. (210.0 to 215.9 mm)
In case of landscape orientation: Short edges 5.83 to 8.50 in. (148.0 to 215.9 mm); Long edges 8.27 to 14.00 in. (210.0 to 355.6 mm)
*16
You can load 60.6 to 65.1 lb Cover (164 to 176 g/m²) heavy paper.
*17
Automatic 2-sided printing can be performed on the custom size paper whose short edges are 5.83 to 8.50 in. (148.0 to 215.9 mm) and long edges are 8.27 to 11.69 in. (210.0 to 297.0 mm).
*18
Automatic 2-sided printing can be performed on the custom size paper whose short edges are 5.83 to 8.50 in. (148.0 to 215.9 mm) and long edges are 8.27 to 14.00 in. (210.0 to 355.6 mm).
*19
The following Index Card size is supported.
3.00 x 5.00 in. (76.2 x 127.0 mm)
About print speed
The print speed may drop depending on the paper settings for the size, type, orientation, and number of copies.
Precautions for paper
Printable area
Envelope sizes
The envelope sizes are as follows.
Chlorine-free paper
Chlorine-free paper can be used with this printer.
