Checking Paper Jams in the Paper Drawer
Referring to the procedure on the display, follow the steps below to remove jammed paper.
1
Press [
2
Open the right cover.
3
Pull out the paper drawer in which a paper jam occurs.
If the paper feeder is installed, pull out the paper drawer of the paper feeder also.
4
Remove the paper by pulling it gently.
If you cannot remove the paper easily, do not try to remove it forcefully but proceed to Step 5 and perform the clearing procedure for another area which is displayed in the message.
5
Set the paper drawer in the printer.
If the paper feeder is installed, insert the paper drawer of the paper feeder also.
6
Close the right cover.
Next, proceed to the clearing procedure for another area which is displayed in the message.
(3) "Checking Paper Jams in the Paper Drawer"
If the jammed paper cannot be found
Paper may be jammed inside the fixing unit.
