Message indicator is on, implement the following solutions.
Message
Cause
Solution
![]() ![]() ("n" represents an alphanumeric character.)
A problem occurred in the fixing unit.
Follow the procedure in "If a Fixing Unit Error Is Displayed", and then contact your local authorized Canon dealer.
A problem occurred inside the printer.
Following the procedure in "If a Service Error Is Displayed", cycle the power of the printer.
USB cable*
(2) Turn the computer off.
(3) Disconnect the cable from the printer.
LAN cable*
(4) Disconnect the cable from the printer.
Power cord
(5) Disconnect the power plug from the AC power outlet.
(6) Disconnect the cord from the printer.
Whether the cable is connected or not varies depending on your environment.
Do not turn ON the printer again.
A fixing unit error is displayed. Do not turn ON the printer after turning it OFF.
If you are not sure what the problem is, contact your local authorized Canon dealer.
If the message reappears, you need to request service.
Follow the procedure below, and then contact your local authorized Canon dealer to request service. |
USB cable*
LAN cable*
Power cord
