Turning the Power On and Specifying a Language
When the printer is turned ON, the initial setting screen appears.
Specify the setting using the following procedure.
About the initial setting screen
The initial setting screen is displayed only when the printer is turned ON for the first time.
1
Press the power switch to turn the printer ON.
The indicators and display on the control panel come on, and the printer initiates a self-diagnostic test on the printer unit and optional accessories.
If no abnormality is found during the self-diagnostic test, the Main Power indicator (green),  Ready indicator (green), Online indicator (green) and Paper Source indicator (green) come on, <Ready to print.> appears in the display, and the printer is ready to print.
Do not turn the printer ON immediately after turning it OFF.
If you want to cycle the power of the printer, wait at least 10 seconds before turning it ON again.
If the printer does not operate properly
If an error message appears in the display on the control panel
When turning ON the printer for the first time after installing the printer and paper feeder
Do not load paper in the paper drawer.
Precautions when turning OFF the printer
If you turn the printer OFF, all print data remaining in the printer memory will be erased.
Power consumption when the power is OFF
Even if the printer is turned OFF, power is still consumed slightly while the power plug is inserted in the AC power outlet.
To stop the power consumption completely, unplug the power plug from the AC power outlet.
2
Select a display language using [ ] and [ ], and then press [OK].
3
Specify a date, and then press [OK].
4
Specify time, and then press [OK].
The following screen appears, and the settings are completed.
About the clock in this printer
The clock in the printer should be accurate within ± 60 seconds per month. Adjust the clock periodically.
When setting time zones and daylight savings time
» Printer Installation » Specifying the Printer's Initial Settings » Turning the Power On and Specifying a Language
07E3-02J
