Registering the Paper Size and Type
When using Drawer 1 or the multi-purpose tray, you need to register the size of the loaded paper because this printer cannot automatically detect the paper size.
When using the optional paper drawer (Drawer 2), register a paper size only in the following cases because the optional paper drawer is configured to automatically detect the paper size by default.
When loading Foolscap or 16K size paper
When loading standard size paper again after using custom size paper
When you want to specify [Mixed Sizes] which does not check the paper size.
Also, it is necessary to set the paper type to match the type of paper that is loaded.
Register the paper size using the following procedure. (The paper size setting is set to [LTR] by default.)
Precautions when specifying [Mixed Sizes]
The printer performs printing without checking the paper settings in the printer driver.
Make sure that the paper specified in the printer driver matches that loaded in the paper drawer before using the printer.
If you are using the UFR II printer driver, load custom size paper whose long edges are 8.50 in. (215.9 mm) or less in portrait orientation.
1
Press [  ] (Feeder Selection).
2
Select the paper source using [  ] and [ ], and then press [OK].
Select either [MP Tray Paper Size], [Drawer 1 Size] or [Drawer 2 Size].
3
Select a paper size using [  ] and [  ], and then press [OK].
Paper size is registered.
4
Select the paper source whose type is to be registered using [  ] and [ ], and press [OK].
Select either [MP Tray Paper Type], [Drawer 1 Type] or [Drawer 2 Type].
Since the printer driver's [Paper Type] default value is [Printer Default], it is normally not necessary to change the printer driver settings.
Whenever you change the printer driver settings, match them with the paper settings on the control panel.
5
Select the paper type with [ ] or [ ], and then press [OK].
The paper type is registered.
Next, specify the following settings.
When printing from the printer driver on Windows or Macintosh, configure the printer driver.
When printing from DOS or UNIX, specify the settings for [Standard Paper Size] and [Default Paper Type] using the control panel.
» Basic Printer Operations » Paper Loading and Output » Registering the Paper Size and Type
07E3-03C
