(1)
An abundant selection of file formats.
(You can store scanned data in a format supported by the TWAIN application you are using.)
Using Adobe Acrobat → PDF
Using Imaging → TIFF/JPEG/BMP
Using imageWARE Document Manager → imageRUNNER ADVANCE exclusive file format
(2)
Enables you to specify the scan area when scanning from the platen glass.
(3)
You can adjust the image.
Change the type of original, and edit the background color and density.
To use the Network Scan function on your imageRUNNER ADVANCE machine, you must first install Color Network ScanGear, included with your machine. The latest version is available for free download from the Canon website.
Compatible OS:
Windows XP/Vista/7/NT4.0/Server 2003/Server 2008 (Mac OS are not supported) |
The method for selecting Scanner differs depending on the application.
When using imageWARE DocumentManager, select [Scan] from the [Tools] menu.
(1)
Specify Color Mode, Resolution, Original Placement, and various other settings.
(2)
Press the Scan button to start scanning.
If you scan using the feeder, you can scan different size originals together. The procedure is described below.
Click the [Main] tab → from the [Original Size] drop-down list, select [Different Size Originals].
