Forwarding Error
Handling Methods |
Delete Failed
TX Jobs |
Handle Files with
Forwarding Errors |
Memory Lock Settings
Stored To
Clear
On
Off
Store
Off
[Send] for Job Status
On
Store/Print
On
Memory RX Inbox
Print
On
Always Print
On
Store/Print
Off
(Settings/Registration) → [Function Settings] → [Send] →[Common Settings] →[Delete Failed TX Jobs].
(Settings/Registration) → [Function Settings] → [Receive/Forward] → [Common Settings] → [Handle Files with Forwarding Errors] → select [Store/Print] or [Always Print] → press [OK].
(Settings/Registration) → [Function Settings] → [Receive/Forward] → [Common Settings] → [Set Fax/I-Fax Inbox].
(Settings/Registration) → [Function Settings] → [Receive/Forward] → [Common Settings] → [Handle Files with Forwarding Errors] → select [Store/Print] → press [OK].
If the Main Menu screen is not displayed, press [Main Menu].
All transmission errors are displayed on the same screen, making forwarding errors indistinguishable from other transmission errors.
Jobs are stored in the machine's memory, and are not deleted even if you turn OFF the main power.
Example:
Set to only perform forwarding during the non-working period between 19:00 on Friday and 8:00 on Monday of the following week.
Start Time: Friday, 19:00
End Time: Monday, 8:00 |
You can store up to seven different combinations of start and end times.
