Category Top
Preface
Digitizing Paper Documents
Scanning the Original and Sending to a Computer
Adding an Image Scanned via Network Scanner to a Document
Enabling PDF Documents to be Edited with Adobe Reader (Reader Extensions)
Converting Scanned Documents into Encrypted Searchable PDF
Using an Advanced Box on the Network
Printer Driver
Merging and Printing Multiple Documents (Windows)
Printing a Booklet (Windows)
Printing a Booklet (Mac)
Using Profiles to Print (Windows)
Selecting Presets for Printing (Mac)
Specifying the Printer Driver Default Settings (Windows)
Fax
Temporarily Storing and Viewing Received Image
Handling Junk Faxes
Automatically Forwarding Received Faxes
Automatically Forwarding Received Faxes to a Computer
Forwarding to a Mobile Computing Device
Handling Files with Forwarding Errors
Checking that a Fax was Sent Successfully
Accessing the Fax Function of a Server Machine
E-Mail
Sending an E-mail to Multiple Destinations
Using a Shared Address Book
Internet Fax/Intranet Fax
Sending a Document via Internet Fax
Receiving a Document via Internet Fax
Department ID Management
Setting a Department ID for Copying
Setting the Department ID Management on the Printer Driver
Security
System Management
Copy Security with Forced Document Scan Lock and Secure Watermark
Secured Print
Data Security
Specifying Send/Fax Security Settings
Restricting Access to the Machine (IPv4)
Restricting Access to the Machine (IPv6)
Advanced Copying and Printing
Scanning Originals while the Machine is Processing a Job (Reserve Copy)
Printing Files Stored in USB Memory Directly from the Machine
Creating Address Labels by Scanning Business Cards
Customizing the Screen Display
Making Favorite Keys Highly Visible
Registering a Series of Frequently Used Functions in One Button (Quick Menu)
Recalling the Quick Menu of Another Machine
Linkage Between imageRUNNER ADVANCE Desktop and imageRUNNER ADVANCE
Automatically Importing Received FAX Documents into Library (imageRUNNER ADVANCE Desktop)
Sending a Fax from a Computer (imageRUNNER ADVANCE Desktop)
Performing Saddle Stitch Printing (imageRUNNER ADVANCE Desktop)
Performing Complex Tasks at the Touch of a Button: Workflow Composer
Creating a Flow on a Computer (Workflow Composer)
Executing a Flow on the Machine (Workflow Composer)
Top » Practical Workflows » Internet Fax/Intranet Fax » Receiving a Document via Internet Fax
07SE-234
Internet Fax (I-fax) is a function that enables you to send and receive images via the Internet, as opposed to a telephone line.
Benefits of Using Internet Fax
Reduce transmission costs
G3 FAX transmission costs increase with transmission time and distance. If a line with fixed rate is installed, you can control the transmission cost because the cost of I-fax is fixed regardless of the transmission time and distance. It is recommended that you use this when sending and receiving documents with a large number of pages.
High resolution transmission
You can receive at a resolution of up to 600 dpi. (for Full mode)
Required Condition
Network settings are set
The sender knows the I-fax address for your machine.
This section describes how to receive I-fax via Full mode from an IPv4 environment.
The screens may differ, depending on the model of the machine and on attached optional products.
Follow the procedures below to check whether the DNS server address settings are set.
Press (Settings/Registration) → [Preferences] → [Network] → [TCP/IP Settings] → [DNS Settings] → [DNS Server Address Settings].
If it is not set, contact the System Manager and set the IP address for DNS primary server and DNS secondary server.
The DNS server is a server that converts the domain name, which is the computer name on the internet, into an IP address.
Check whether the host name and domain name are set in [DNS Host/Domain Name Settings] for <IPv4> on the DNS Settings screen.
If it is not set, ask your System Manager to set the host name and domain name. For the domain name, enter the domain name of the network to which the machine belongs to.
If dynamic DNS server is set, press [On] for <DNS Dynamic Update> in [DNS Dynamic Update Settings] on the DNS settings screen.
4.
Follow the procedures below to check whether the basic settings for the e-mail server are set.
Press (Settings/Registration) → [Function Settings] → [Send] → [E-Mail/I-Fax Settings] → [Communications Settings].
If they are not set, ask your System Manager to specify the settings.
[E-Mail Address]:
The e-mail address set on the machine.
[SMTP Server]:
The IP address or host name of the e-mail server used for transmission.
5.
Press [Next] → check whether the settings for the POP server are set.
[POP Server]:
The IP address and host name of the e-mail server used to send and receive in "POP before SMTP" send authentication format.
[POP Login Name]:
The login name used to access the POP server.
[POP Password]:
The password used to access the POP server.
[POP Interval]:
The time interval at which the machine checks the e-mail on the e-mail server.
It is recommended that you set [POP Interval] to an interval other than '0'.
6.
If the receiving server requires authentication, check the authentication system by pressing [Next] → [Next].
If authentication is not set, ask your System Manager to specify the settings.
[POP Authentication Before Send]:
If the provider is in the "POP before SMTP" send authentication system, set this setting to 'On'.
[SMTP Authentication (SMTP AUTH)]:
If the environment of the e-mail server requires SMTP authentication, set this setting to 'On' and enter the user name and password.
7.
Follow the procedures below to set [Use Send Via Server] to 'On'.
Press (Settings/Registration)→ [Function Settings] → [Send] → [E-Mail/I-Fax Settings] → [Use Send Via Server].
The preparations for receiving I-fax are completed.
8.
Press [Status Monitor/Cancel] → [Receive] → [Check I-Fax RX] → check that the job was successfully received.
Reference Information
Difference between Simple Mode and Full Mode
You cannot check whether the data was received correctly by the recipient in the Simple mode. However, you can check whether the data was received correctly by the recipient in the Full mode. Thus, it is recommended that Full mode is set when you are receiving a data.
