Executing a Flow on the Machine (Workflow Composer)
You can execute a flow you have created on a machine with Workflow Composer installed.
Required Condition
Workflow Composer is installed in the machine you are using.
Users of the machine you are using are managed with the SSO-H authentication system.
Shared folder for file transmission is created on the computer you are using (the folder name must be the same as the login user name).
This section describes how to log in to the machine you are using as 'John', and execute a Shared flow.
The screens may differ, depending on the model of the machine and on attached optional products.
Follow the procedures below.
Executing a Shared Flow
Enter [User Name] and [Password] on the Log In screen of a machine with Workflow Composer installed → press [Log In]
As an example, 'John' is used for [User Name], and 'password' is used for [Password].
The Main Menu screen is displayed.
Place the 11" ×17" original on the feeder or the platen glass.
Press [Workflow Composer] on the Main Menu screen.
If [Workflow Composer] is not displayed on the Main Menu screen, press [  ]/[Show All]. If [Workflow Composer] is still not displayed even when you press [  ]/[Show All], confirm whether Workflow Composer has been started.
4.
On the Workflow Composer Basic Features screen, select [Shared] → press [Reduce paper size and send].
5.
Check the flow settings → press [Start].
The 11" ×17" original is reduced to LGL size, converted to a PDF file, and sent to the file server.
Check that the PDF was sent to the following folder, as specified in the settings of the flow:
\\file-server\sales\John
You must create the shared folder, \sales\John, in the file server, for the PDF to be sent according to the settings of the Shared flow.
