Using the Machine as a Scanner
0KCF-06W
Changing Default Scan Settings
Change the default settings to match the operations that you perform frequently.
USB memory
  <Scan Settings>    <USB Memory Settings>    <Change Default Settings>    Select the setting    Change the default value of the selected item  <Apply>
Settings
Select the item you want to set, and change the default value.
E-mail
  <Scan Settings>    <E-Mail Settings>    <Change Default Settings>    Select the setting    Change the default value of the selected item  <Apply>
Settings
File server
  <Scan Settings>    <File Settings>    <Change Default Settings>    Select the setting    Change the default value of the selected item  <Apply>
Settings
