Specifying Destinations in an LDAP Server (E-mail)
If your office has an LDAP server installed, you can use the destinations registered in the server. To specify destinations, access an LDAP server via the machine, and then search for a destination.
You need to specify the settings for connecting to an LDAP server beforehand.
1
Press
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_scan18.gif)
2
Use
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_up18.gif)
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_down18.gif)
to select <Specify from LDAP Server>, and press
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_ok18.gif)
3
Select the LDAP server you are using, and press
4
Select the search criterion, and press
Personal names, fax numbers, e-mail addresses, organization names, and department names are available criteria for searching destinations.
5
Enter the search keyword using the numeric keys, select <Apply>, and press
The following screen shows an example for when <Name> is selected in step 4 to search by personal name.
Pressing
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_tone18.gif)
toggles the input modes (except for searching by fax number).
To specify multiple search criteria, repeat steps 4 and 5.
6
Select <Search Meth.>, and press
7
Specify the search method, and press
<Using All Conditions Below>
Searches and displays the destinations that meet all the search criteria specified in steps 4 and 5.
<Using Some Conditions Below>
All destinations meeting any of the search criteria specified in steps 4 and 5 are displayed as search results.
8
Select <Start Search>, and press
The destinations meeting your search criteria are displayed.
NOTE:
If the authentication screen appears when you start searching, enter the user name and password registered in the LDAP server, select <Apply>, and press
. You can enter the user name and password of the machine or yours, depending on the setting (
Registering LDAP Servers (imageRUNNER 1435iF / 1435i Only)). If you are not sure, ask your Network Administrator.
9
Select a destination, select <Apply>, and press
Up to 10 destinations can be specified.
To search for a destination using other search criteria, repeat steps 2 to 9.
NOTE:
If you have already specified a destination using the numeric keys, up to nine destinations can be specified using an LDAP server.
You cannot specify the selected destinations as Cc or Bcc addresses.
![](./images/book_images/b_C241.gif)
To delete destinations
![](./images/global_images/1T0002134966/g_ne_toggle_open.gif)
If you specified multiple destinations, you can delete destinations as necessary.
1
Select <Confirm/Edit Destination>, and press ![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_ok18.gif) .
2
Select a destination you want to delete, and press ![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_ok18.gif) .
3
Select <Delete Destination>, and press ![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_ok18.gif) .
4
Select <Yes>, and press ![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_ok18.gif) .
If you want to easily and quickly delete destinations without displaying a list of destinations
Before selecting <Confirm/Edit Destination> in step 1, you can press ![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_left18.gif) / ![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_right18.gif) to toggle the destinations you specified. Display a destination you want to delete ![](./images/book_images/b_key_arrow_right.gif) <Yes> ![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_ok18.gif) .
LINKS
