      0KCF-06E
      Adjusting Balance between File Size and Image Quality
      You can specify the file compression ratio that is applied when the documents are scanned in the file format you specified (Selecting a File Format). <Small: Memory Priority> makes the compression ratio higher than normal to create smaller files with lower image quality. On the other hand, <Large: Image Quality Priority> makes the compression ratio lower than normal larger files with higher image quality.
        Specify destinations or connect the USB memory device <Data Size>    Specify the setting
      The data size is highly compressed and reduced, but the image quality becomes low.
      <Standard>
      The compression ratio and the image quality are adjusted to an intermediate setting between <Small: Memory Priority> and <Large: Image Quality Priority>.
      The image quality improves, but the data compression ratio decreased and data size becomes large.
