Scanning from the Machine
The sequence of "scanning a document and saving it to a computer" can only be done when scanning from the machine. Before you can use this function, you need to complete some procedures.
Configure the settings on the machine and your computer by following the procedure below.
Configuring the Machine
1
Start the Remote UI and log on in System Manager Mode.
Starting the Remote UI
2
Configure the settings on the [Edit WSD Settings] page.
To access the page, click [Settings/Registration]
[Network Settings]
[TCP/IP Settings]
[Edit...] in [WSD Settings].
3
Restart the machine.
Turn OFF the machine, wait for at least 10 seconds, and turn it back ON.
Configuring Your Computer
4
5
Click [Add a device] (or [Add a printer]) and follow the on-screen instructions.
1
Place the document.
Placing Documents
2
Press
3
Use
to select <Computer>, and press
4
Select the destination or type of scan, and press
NOTE:
Only one computer that the machine first established communication with is displayed at a time.
5
Select <Scan>, and press
Scanning starts.
If you want to cancel scanning, select <Cancel>
<Yes>
Other useful scanning functions
You can save scanned documents to a USB memory device or send them as e-mail attachments. The documents can also be saved to file servers. You can accomplish these functions directly from the machine.
