The machine comes pre-configured with factory default settings (Setting Menu List). You can change and register the default settings according to your needs.
Specify <PDF (Compact)> as the default file format, and register it as the default setting. From now on, you will not have to change the file format when scanning. Changing Default Scan Settings
Specify the e-mail address of your client with <Color> and <JPEG> for scan settings, and register the address and settings as a combination in <Favorite Settings>. Registering Frequently Used Scan Settings (E-mail/File Server)
