All the settings about the scan are listed with short descriptions. Default settings are marked with a dagger (
Asterisks (*)
Settings marked with "*1" are only available for the imageRUNNER 1435iF / 1435i.
Settings marked with "*2" are only available for the imageRUNNER 1435iF / 1435i with the optional Send PDF Security Feature Set enabled.
Only either of the settings marked with "*3" is available at a time, depending on the PDF encryption setting (256-bit AES Settings for Encrypted PDF).
Scan Size
LTR
![]() LGL
STMT
Color Mode
Color
![]() Black & White
File Format
PDF
![]() PDF (Compact)
PDF (Compact/OCR)*1
PDF (OCR)*1
Set PDF Details*2
PDF
Encryption Level: None
, Acrobat 7.0 or Later/128-bit AES, Acrobat 9.0 or Equivalent/256-bit AES*3, Acrobat 10.0 or Equivalent/256-bit AES*3Digital Signatures: None
, Top LeftPDF (Compact)
, Top LeftPDF (Compact/OCR)
, Top LeftPDF (OCR)
, Top LeftJPEG
TIFF
Density
Nine Levels
Original Orientation
Portrait
![]() Landscape
Original Type
Text
Text/Photo
![]() Photo
2-Sided Original
Off
![]() Book Type
Calendar Type
Sharpness
Seven Levels
Data Size
Small: Memory Priority
Standard
![]() Large: Image Quality Priority
<Scan Settings>
<USB Memory Settings>
<Initialize Default Settings>
<Yes>
Scan Size
LTR
![]() LGL
STMT
Color Mode
Color
![]() Black & White
File Format
PDF
![]() PDF (Compact)
PDF (Compact/OCR)
PDF (OCR)
JPEG
TIFF
Set PDF/TIFF Details
PDF
Encryption Level*2 : None
, Acrobat 7.0 or Later/128-bit AES, Acrobat 9.0 or Equivalent/256-bit AES*3, Acrobat 10.0 or Equivalent/256-bit AES*3Digital Signatures*2: None
, Top LeftDivide into Pages: Off
, OnPDF (Compact)
Encryption Level*2: None
, OnPDF (Compact/OCR)
, OnPDF (OCR)
, OnTIFF
, OnDensity
Nine Levels
Portrait
![]() Landscape
Original Type
Text
Text/Photo
![]() Photo
2-Sided Original
Off
![]() Book Type
Calendar Type
Sharpness
Seven Levels
Data Size
Standard
Subject/Message
Subject
Message
Reply To
None
![]() Specify from Address Book
Priority
Low
Standard
![]() High
<Scan Settings>
<E-Mail Settings>
<Register Unit Name (E-Mail)>
Enter the sender name
<Apply>
<Scan Settings>
<E-Mail Settings>
<Yes>
Scan Size
LTR
![]() LGL
STMT
Color Mode
Color
![]() Black & White
File Format
PDF
![]() PDF (Compact)
PDF (Compact/OCR)
PDF (OCR)
JPEG
TIFF
PDF
, OnPDF (Compact)
, OnPDF (OCR)
, OnTIFF
, OnDensity
Nine Levels
Portrait
![]() Landscape
Original Type
Text
Text/Photo
![]() Photo
2-Sided Original
Off
![]() Book Type
Calendar Type
Sharpness
Seven Levels
Data Size
Standard
<Scan Settings>
<File Settings>
<Yes>
Gamma 1.0
Gamma 1.4 Gamma 1.8 ![]() Gamma 2.2 |
Level in Text/Photo Mode or Photo Mode
Data Size Priority
Normal ![]() Image Quality Priority Level in Text Mode
Data Size Priority
Normal ![]() Image Quality Priority |
Smart Scan
Off
On
<Scan Settings>
<OCR (Text Searchable) Settings>
<Smart Scan>
Select <Off> or <On>
<Scan Settings>
<256-bit AES Settings for Encrypted PDF>
Select <Acrobat 9.0 or Equivalent> or <Acrobat 10.0 or Equivalent>
