You can specify the gamma value that is applied when the documents are scanned in the file format you specified (Selecting a File Format). You can specify the same gamma value as that of the monitor which is to be used for viewing the converted files so the files are displayed with brightness true to the original documents.
For the gamma value of a monitor display, see the instruction manual included with the display.
