      0KCF-06X
      Registering Frequently Used Scan Settings (E-mail/File Server)
      You can register up to 18 frequently used combinations of scan settings with desired destinations. You can recall the registered setting combination when it is needed.
      1
      Press .
      2
      Use / to select <E-Mail> or <File>, and press .
      3
      Specify the destinations to register.
      For instructions on how to use the Address Book, see Specifying Destinations (E-mail/File Server) (imageRUNNER 1435iF / 1435i Only).
      4
      Select <Favorite Settings>, and press .
      5
      Select <Register/Delete>, and press .
      Confirm the message on the display, select <OK>, and press .
      6
      Select from <Settings 1> to <Settings 18>, and press .
      7
      Specify the scan settings and change the setting name as necessary.
      Use / to select the settings. Specifying Detailed Settings
      To change the setting name, select <Change Name>    enter the name  <Apply>  .
      NOTE:
      You can register up to 20 characters that are entered for <Subject/Message> (subject and body) in the e-mail setting.
      8
      Select <Apply>, and press .
      9
      Select <Yes>, and press .
      If you want to edit a registered setting, press   <Favorite Settings>    <Edit/Delete>    select the setting    edit the setting    <Apply>    <Yes>  . You cannot change the destinations registered in the setting with this procedure. Register a new setting with the desired destinations.
      If you want to delete a registered setting, press   <Favorite Settings>    <Edit/Delete>    select the setting    <Delete>    <Yes>  .
      Registered settings are saved even when the machine is turned OFF.
      Using a Registered Setting
      To use a registered setting, press   <Favorite Settings>    select the setting to recall  . You can change the settings in a setting combination after it is recalled.
