User authentication for scanning documents
When you press
, a logon screen may appear. For instructions on how to log on, see Logging on to Authorized Send (imageRUNNER 1435iF / 1435i Only).![]() When specifying destinations for e-mails
You can specify multiple destinations, including Cc/Bcc destinations, just like you can when sending normal e-mails. These destinations can be specified using the Address Book or an LDAP server. To specify destinations as Cc or Bcc addresses, you need to use the Address Book.
When specifying destinations for a file server
You cannot specify destinations using the numeric keys or an LDAP server. Furthermore, only one destination can be specified at a time.
TIPS for Enhancing Security
If you want to limit available destinations to ones from the Address Book, ones in an LDAP server, or previously specified ones:
If you want to disable specifying previously used destinations:
If you want to limit the available destination to the e-mail address of the user or the folder assigned to the user:
