About the menu options in the following chart
Default settings are highlighted in bold.
Settings
Descriptions
WPS Push Button Mode
Use the access point WPS button to connect wirelessly using WPS.
WPS PIN Code Mode
Send a PIN code to the access point to connect wirelessly using WPS.
SSID Settings
Enter the WEP key or PSK needed to connect with the access point.
Wireless LAN Information
It displays information about the current wireless LAN connection.
Settings
Descriptions
IPv4 Settings
Specify IP address (IPv4).
IP Address Settings
Enter the IP address.
An IP address is a number to identify the communication devices (computers, printers, etc.) connected to a network which uses the TCP/IP protocol.
PING Command
Program for diagnosing TCP/IP network.
You can check whether the machine connects to the computer or not.
DNS Settings
DNS is a system which assigns a name (domain name) to a server on a network to correspond with the IP address of the server.
mDNS Settings
Enables DNS functionality without a specific server such as DNS.
DHCP Option Settings
Specify whether to acquire the Host Name and whether to perform DNS Dynamic Update.
IPv6 Settings
IPv6 is a communication protocol equivalent to an advanced version (Version 6) of the Internet Protocol (IP).
Use IPv6
Specify IP address (IPv6).
Stateless Address Settings
Specify whether to use the stateless address.
Use DHCPv6
Specify whether to use DHCPv6 (stateless address).
DNS Settings
mDNS Settings
WINS Settings
WINS is a service for associating the NetBIOS names (names of computers and printers on a network) with the IP address.
LPD Settings
LPD is a print application available in Windows, Mac OS X, UNIX, and Linux.
This is generally used in a TCP/IP protocol network environment.
RAW Settings
RAW is a print application available in Windows.
When using RAW, printing speed is faster than when using LPD.
WSD Settings
WSD is a print application available in Windows Vista/7/Server 2008.
Use WSD protocol to search printers automatically and obtain information for jobs or printers.
Use HTTP
Specify whether to use HTTP communication (Remote UI via Web browser).
Port Number Settings
Depending on your network environment, you can change the port number for each protocol.
MTU Size
Select MTU.
Settings
Descriptions
SNMPv1 Settings
Specify whether to use SNMPv1, and set the Community Name and access rights used by SNMP.
SNMPv3 Settings
Specify whether to use SNMPv3.
Printer Management Information From Host
Specify whether to acquire printer management information periodically from host.
Settings
Descriptions
Auto Detect
Specify whether to search automatically.
MAC Address
A MAC address is a particular number assigned to each communication device (computers, printers, etc.) connected to a network.
