To set SNMPv3
You need to activate SSL features in advance.
SNMPv3 settings
<SNMPv3 Settings> Details can be set only via Remote UI.
(1)
Select the [Use SNMPv3] check box.
(2)
Select the [Enable User] check box.
(3)
Specify the SNMPv3 protocol.
[Use SNMPv3]
When the check box is selected, you can use SNMPv3 protocol.
[User Name]
Enter a user name.
[MIB Access Permission]
Specify MIB access authority. When both reading and writing is permitted, a user can access this product from a computer on the network and change settings.
[Security Setting]
Specify securities.
[Authentication Algorithm]
Select an algorithm to be used for authentication.
To change the password, select the [Change Password] check box and enter 6 to 16 alphanumeric characters in [Authentication Password] and [Confirm].
[Encryption Algorithm]
Select an algorithm to be used for encryption.
To change the password, select the [Change Password] check box and enter 6 to 16 alphanumeric characters in [Encryption Password] and [Confirm].
] (Menu).
] or [
] and press [OK].
] (Log In/Out).
] or [
] and press [OK].
] or [
] and press [OK].
] or [
] and press [OK].
<Off>
SNMPv3 protocol is not available.
<On>
SNMPv3 protocol is available.
] (Menu) to close the menu screen.
