Setting Protocol Port Numbers
Configure the port number and protocol for the printer connection to work with your network.
When the setup is complete
Restart the machine to take effect the settings.
1
Press [
] (Menu).
2
Select <Network Settings> using [
] or [
] and press [OK].
When the system manager ID and system manager PIN are specified
Use the numeric keys to enter the ID and number, and then press [
] (Log In/Out).
3
Select <TCP/IP Settings> using [
] or [
] and press [OK].
4
Select <Port Number Settings> using [
] or [
] and press [OK].
5
Select the protocol that uses the port number you want to change using [
] or [
] and press [OK].
6
Enter a port number and press [OK].
7
Press [
] (Menu) to close the menu screen.
8
Restart the machine.
It is necessary to restart the machine to take effect the settings.
Turn OFF the machine and wait for at least 10 seconds before turning it back ON.
