Setting the Dedicated Port
Enable or disable the dedicated port settings.
If the dedicated port is set to be disabled, you cannot scan/print, or configure/check the settings for this product when using the printer driver or the MF Toolbox by connecting the network.
When the setup is complete
Restart the machine to take effect the settings.
1
Press [
] (Menu).
2
Select <Network Settings> using [
] or [
] and press [OK].
When the system manager ID and system manager PIN are specified
Use the numeric keys to enter the ID and number, and then press [
] (Log In/Out).
3
Select <Dedicated Port Settings> using [
] or [
] and press [OK].
4
Select <Off> or <On> using [
] or [
] and press [OK].
<Off>
Do not use a dedicated port.
<On>
Use a dedicated port.
5
Press [
] (Menu) to close the menu screen.
6
Restart the machine.
It is necessary to restart the machine to take effect the settings.
Turn OFF the machine and wait for at least 10 seconds before turning it back ON.
