e-ManualTopSite mapHelp
Chapter Top
Printing Fundamentals
Printing
Setting the Printer Options
Viewing the Online Help
Printing Functions
Common Functions
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
[Device Settings] Tab
Scaling Documents
1-sided Printing and 2-sided Printing
Attention (1-sided Printing and 2-sided Printing)
Booklet Printing
Poster Printing
Watermark Printing
Printing from a Computer (Macintosh)
Printing
Viewing the Driver Guide
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
Scaling Documents
1-sided and 2-sided Printing
Using [Presets] for Printing
Setting Priority (When Specifying the Same Item Using Multiple Methods)
Functions Which Can Be Specified from the Control Panel
Printing without the Printer Driver (Direct Print)
Printing the PDF File Using the Direct Print Function
Printing the PS/EPS File Using the Direct Print Function
Printing the TIFF/JPEG File Using the Direct Print Function
Printing the XPS File Using the Direct Print Function
Direct Printing from Command Prompt
Printing Files Directly from USB Memory Devices (USB Direct Print)
Printing Directly from USB Memory Device
Print Setting Menu List
Changing the Default Print Settings and File Sorting Criteria
Remove the USB Memory Device
Receiving E-mail Data on the Mail Server and Printing (E-mail Print)
How to Specify the Settings for E-mail Print
Attention (How to Specify the Settings for E-mail Print)
Receiving and Printing E-mails Manually
Printing the E-mail Receive Log List
Attention (Printing E-mail Sending/Receiving History)
When E-mail Print Fails
Printing Files from the Printer Using FTP Client
Specifying a Password for a Document and Printing (Secured Print)
Attention (Specifying a Password for a Document and Printing (Secured Print))
Saving a Document in the SD Card in the Printer (Stored Job Print)
Performing a Stored Job Print Using the Control Panel of the Printer
Displaying or Operating the Jobs Stored in a Box (Resume/Delete)
Automatically Deleting Files Stored in a Box
Changing the Box Settings
Giving Priority to a Print Job (Interrupt Printing)
Top » Useful Printing Functions » Functions Which Can Be Specified from the Control Panel
08X4-062
This printer allows you to specify the printing functions from the printer driver. However, some printing functions are specified from the control panel or the Remote UI. The following table shows the functions to be specified from the control panel or the Remote UI.
For details on the items you can manage using the control panel, see "Setting Items."
Function
Overview of the Function
Multi-purpose tray paper size
Specifies the size of the paper loaded in the multi-purpose tray.
Multi-purpose tray priority
Specifies whether the printer should detect the paper source in order starting with the multi-purpose tray.
Drawer N (N=1, 2, 3) size
Specifies the size of the paper loaded in the paper drawer (Drawer 1 or 2).
Standard paper size
Since paper size cannot be specified when printing from DOS, UNIX or other operating system, specify it using this setting.
Diff. paper tray
Specifies whether to use the multi-purpose tray when the paper settings for the selected paper source are not the same as the paper settings in the received data.
Auto selection
Specifies the paper source to be automatically selected.
Standard paper type
Since paper type cannot be specified when printing from DOS, UNIX or other operating system, specify it using this setting.
Adjust Print Position
Adjusts the printing position in the vertical direction (Y) or the horizontal direction (X).
Alternative method
If the last page for the 2-sided printing is 1-sided printing, 1-sided printing is applied to the last page.
Image Refinement
Set whether to use the smoothing process to print the jagged edges of text and graphics.
Recovery printing
Specifies whether to print the partially printed page when the printer stops printing due to a paper jam or an error occurring.
Check paper size
Specifies whether the printer should stop printing, displaying the message <Check paper size.> or continue printing.
Substitute size
The printer switches the paper size if the paper of the size to be used is not loaded in the printer.
Plain paper curl adjustment
If printed plain paper curls, specify the setting for this item.
