e-ManualTopSite mapHelp
Chapter Top
Printing Fundamentals
Printing
Setting the Printer Options
Viewing the Online Help
Printing Functions
Common Functions
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
[Device Settings] Tab
Scaling Documents
1-sided Printing and 2-sided Printing
Attention (1-sided Printing and 2-sided Printing)
Booklet Printing
Poster Printing
Watermark Printing
Printing from a Computer (Macintosh)
Printing
Viewing the Driver Guide
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
Scaling Documents
1-sided and 2-sided Printing
Using [Presets] for Printing
Setting Priority (When Specifying the Same Item Using Multiple Methods)
Functions Which Can Be Specified from the Control Panel
Printing without the Printer Driver (Direct Print)
Printing the PDF File Using the Direct Print Function
Printing the PS/EPS File Using the Direct Print Function
Printing the TIFF/JPEG File Using the Direct Print Function
Printing the XPS File Using the Direct Print Function
Direct Printing from Command Prompt
Printing Files Directly from USB Memory Devices (USB Direct Print)
Printing Directly from USB Memory Device
Print Setting Menu List
Changing the Default Print Settings and File Sorting Criteria
Remove the USB Memory Device
Receiving E-mail Data on the Mail Server and Printing (E-mail Print)
How to Specify the Settings for E-mail Print
Attention (How to Specify the Settings for E-mail Print)
Receiving and Printing E-mails Manually
Printing the E-mail Receive Log List
Attention (Printing E-mail Sending/Receiving History)
When E-mail Print Fails
Printing Files from the Printer Using FTP Client
Specifying a Password for a Document and Printing (Secured Print)
Attention (Specifying a Password for a Document and Printing (Secured Print))
Saving a Document in the SD Card in the Printer (Stored Job Print)
Performing a Stored Job Print Using the Control Panel of the Printer
Displaying or Operating the Jobs Stored in a Box (Resume/Delete)
Automatically Deleting Files Stored in a Box
Changing the Box Settings
Giving Priority to a Print Job (Interrupt Printing)
Top » Useful Printing Functions » Printing from a Computer (Windows) » Printing Multiple Pages on One Sheet
08X4-0S6
Multiple pages can be printed on one sheet of paper.
Click [Page Setup].
For instructions on how to display the printer driver screen, see "Printing" or "Configuring the Default Print Settings."
Select [N on 1] from [Page Layout] (where "N" is the number of pages you want to print on the sheet).
Note
If you cannot select the options for [Page Layout], display the [Device Settings] tab, and then select [Auto] or [Enabled] from [Spooling at Host]. For instructions on how to display the [Device Settings] tab, see "Setting the Printer Options."
Select the page order from [Page Order].
The output image is displayed in the preview area.
4.
Click [OK].
You cannot enlarge and reduce manually when using this function.
Although there may be a function for printing multiple copies depending on the application you are using, do not use it together with this function. If you do, printing may not be executed correctly.
The display may vary according to the operating system, as well as the type and version of the printer driver.
