e-ManualTopSite mapHelp
Chapter Top
Printing Fundamentals
Printing
Setting the Printer Options
Viewing the Online Help
Printing Functions
Common Functions
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
[Device Settings] Tab
Scaling Documents
1-sided Printing and 2-sided Printing
Attention (1-sided Printing and 2-sided Printing)
Booklet Printing
Poster Printing
Watermark Printing
Printing from a Computer (Macintosh)
Printing
Viewing the Driver Guide
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
Scaling Documents
1-sided and 2-sided Printing
Using [Presets] for Printing
Setting Priority (When Specifying the Same Item Using Multiple Methods)
Functions Which Can Be Specified from the Control Panel
Printing without the Printer Driver (Direct Print)
Printing the PDF File Using the Direct Print Function
Printing the PS/EPS File Using the Direct Print Function
Printing the TIFF/JPEG File Using the Direct Print Function
Printing the XPS File Using the Direct Print Function
Direct Printing from Command Prompt
Printing Files Directly from USB Memory Devices (USB Direct Print)
Printing Directly from USB Memory Device
Print Setting Menu List
Changing the Default Print Settings and File Sorting Criteria
Remove the USB Memory Device
Receiving E-mail Data on the Mail Server and Printing (E-mail Print)
How to Specify the Settings for E-mail Print
Attention (How to Specify the Settings for E-mail Print)
Receiving and Printing E-mails Manually
Printing the E-mail Receive Log List
Attention (Printing E-mail Sending/Receiving History)
When E-mail Print Fails
Printing Files from the Printer Using FTP Client
Specifying a Password for a Document and Printing (Secured Print)
Attention (Specifying a Password for a Document and Printing (Secured Print))
Saving a Document in the SD Card in the Printer (Stored Job Print)
Performing a Stored Job Print Using the Control Panel of the Printer
Displaying or Operating the Jobs Stored in a Box (Resume/Delete)
Automatically Deleting Files Stored in a Box
Changing the Box Settings
Giving Priority to a Print Job (Interrupt Printing)
Top » Useful Printing Functions » Receiving E-mail Data on the Mail Server and Printing (E-mail Print) » How to Specify the Settings for E-mail Print » Attention (How to Specify the Settings for E-mail Print)
08X4-06K
The following are settings for printing e-mails.
You can set them from the printer control panel, Remote UI or FTP client.
: Can be specified: Cannot be specified
Settings for Using the POP3 Protocol
Option
Setting
Setting Method
Control Panel
Remote UI
FTP Client
POP3 Server Name
Specifies the name or sets the IP address of the server which receives e-mails.
POP3 User Name
Specifies the name of the user which receives e-mails.
Password
Specifies the password for the name of the user which receives e-mails.
POP3 RX Interval
Set the interval for automatically connecting to the server that receives e-mails in minute units. Receive e-mail at specified intervals and print it automatically.
POP3 RX
Specifies whether to enable the e-mail print function. When it is enabled, e-mail is automatically received and printed.
POP3 Server Port Number
Specifies the port number for the server which receives e-mails.
E-Mail RX
Performs manual receiving of e-mails.
Settings for Using the SMTP Protocol
Option
Setting
Setting Method
Control Panel
Remote UI
FTP Client
SMTP RX
Select whether to enable the e-mail printing function. When it is enabled, e-mail is automatically received and printed.
SMTP Server Port Number
Other Settings
Option
Setting
Setting Method
Control Panel
Remote UI
FTP Client
Print History List (E-Mail Print)
Prints e-mail print logs.
Show Warnings
Specifies whether a message should appear or any indicator should blink when a reception error has occurred on printing e-mails.
Print E-Mail Text
Specifies whether the printer should print the text on printing e-mails.
Limit E-Mail Print
Specifies whether to limit the number of the print pages of e-mail text.
