If you have registered frequently used settings as "profiles," you can apply the settings by simply selecting them from the [Profile] list.
Specify the desired settings in the printer driver screen → click [Add].
Click the tabs for the [Page Setup], [Finishing], [Paper Source], and [Quality] tabs, and then specify the desired items.
For instructions on how to specify the print settings, see "
Printing" or "
Configuring the Default Print Settings."
For information on available printing functions, see "
Printing Functions" or the online help (see "
Viewing the Online Help").
Set [Name] and [Icon] → click [OK].
Enter additional information in [Comment] if necessary.
To edit or delete a profile, in the printer driver screen, click [Edit] at the right of [Profile]. However, pre-defined profiles cannot be modified.
If you cannot select a profile, display the printer properties dialog box from [Control Panel], click the [Profile] tab, and then check whether [Allow Profile Selection] and [Allow Setting Addition] are selected. For details about how to display the printer properties dialog box, see " Setting the Printer Options."
The display may vary according to the operating system, as well as the type and version of the printer driver.
