e-ManualTopSite mapHelp
Chapter Top
Printing Fundamentals
Printing
Setting the Printer Options
Viewing the Online Help
Printing Functions
Common Functions
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
[Device Settings] Tab
Scaling Documents
1-sided Printing and 2-sided Printing
Attention (1-sided Printing and 2-sided Printing)
Booklet Printing
Poster Printing
Watermark Printing
Printing from a Computer (Macintosh)
Printing
Viewing the Driver Guide
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
Scaling Documents
1-sided and 2-sided Printing
Using [Presets] for Printing
Setting Priority (When Specifying the Same Item Using Multiple Methods)
Functions Which Can Be Specified from the Control Panel
Printing without the Printer Driver (Direct Print)
Printing the PDF File Using the Direct Print Function
Printing the PS/EPS File Using the Direct Print Function
Printing the TIFF/JPEG File Using the Direct Print Function
Printing the XPS File Using the Direct Print Function
Direct Printing from Command Prompt
Printing Files Directly from USB Memory Devices (USB Direct Print)
Printing Directly from USB Memory Device
Print Setting Menu List
Changing the Default Print Settings and File Sorting Criteria
Remove the USB Memory Device
Receiving E-mail Data on the Mail Server and Printing (E-mail Print)
How to Specify the Settings for E-mail Print
Attention (How to Specify the Settings for E-mail Print)
Receiving and Printing E-mails Manually
Printing the E-mail Receive Log List
Attention (Printing E-mail Sending/Receiving History)
When E-mail Print Fails
Printing Files from the Printer Using FTP Client
Specifying a Password for a Document and Printing (Secured Print)
Attention (Specifying a Password for a Document and Printing (Secured Print))
Saving a Document in the SD Card in the Printer (Stored Job Print)
Performing a Stored Job Print Using the Control Panel of the Printer
Displaying or Operating the Jobs Stored in a Box (Resume/Delete)
Automatically Deleting Files Stored in a Box
Changing the Box Settings
Giving Priority to a Print Job (Interrupt Printing)
Top » Useful Printing Functions » Printing from a Computer (Windows) » 1-sided Printing and 2-sided Printing
08X4-0S7
You can select whether to print on one side or both sides of each sheet of paper.
The default setting for [Print Style] is [2-sided printing].
Paper Type
Paper Size
Plain paper
(16.0 to 23.9 lb Bond (60 to 90 g/m²))
Heavy paper
(24.0 lb Bond to 44.4 lb Cover (91 to 120 g/m²))
Standard size paper
A4, Legal, Letter and Foolscap
Custom size paper:
8.27 to 8.50 in. (210.0 to 215.9 mm) wide and 11.00 to 14.00 in. (279.4 to 355.6 mm) long
Before performing 2-sided printing, see "Attention (1-sided Printing and 2-sided Printing)."
Precautions when performing 2-sided printing
Do not touch the paper during 2-sided printing until it is completely output. The paper is first partially output after the front side is printed, and then it is fed again to be printed on the back side.
Be sure to close the output selection cover before performing 2-sided printing.
Printing on the back side of paper that was previously printed (performing 2-sided printing manually)
The printer can manually print the back side* of paper that has been printed once.
When printing on the back side of paper whose front side was previously printed, flatten out any curled paper and load one sheet of paper at a time in the multi-purpose tray.
This is only for paper that has been printed using this printer. Also, you cannot print again on the same side of the paper that was printed before.
Click [Finishing].
For instructions on how to display the printer driver screen, see "Printing" or "Configuring the Default Print Settings."
Select [1-sided Printing] or [2-sided Printing] from [Print Style]
The default setting for [Print Style] is [2-sided Printing]. You can also change the default setting to [1-sided Printing]. For instructions on changing the default settings, see "Configuring the Default Print Settings."
Select the binding edge from [Binding Location].
The output image is displayed in the preview area.
4.
Click [OK].
Note
The display may vary according to the operating system, as well as the type and version of the printer driver.
