e-ManualTopSite mapHelp
Chapter Top
Printing Fundamentals
Printing
Setting the Printer Options
Viewing the Online Help
Printing Functions
Common Functions
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
[Device Settings] Tab
Scaling Documents
1-sided Printing and 2-sided Printing
Attention (1-sided Printing and 2-sided Printing)
Booklet Printing
Poster Printing
Watermark Printing
Printing from a Computer (Macintosh)
Printing
Viewing the Driver Guide
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
Scaling Documents
1-sided and 2-sided Printing
Using [Presets] for Printing
Setting Priority (When Specifying the Same Item Using Multiple Methods)
Functions Which Can Be Specified from the Control Panel
Printing without the Printer Driver (Direct Print)
Printing the PDF File Using the Direct Print Function
Printing the PS/EPS File Using the Direct Print Function
Printing the TIFF/JPEG File Using the Direct Print Function
Printing the XPS File Using the Direct Print Function
Direct Printing from Command Prompt
Printing Files Directly from USB Memory Devices (USB Direct Print)
Printing Directly from USB Memory Device
Print Setting Menu List
Changing the Default Print Settings and File Sorting Criteria
Remove the USB Memory Device
Receiving E-mail Data on the Mail Server and Printing (E-mail Print)
How to Specify the Settings for E-mail Print
Attention (How to Specify the Settings for E-mail Print)
Receiving and Printing E-mails Manually
Printing the E-mail Receive Log List
Attention (Printing E-mail Sending/Receiving History)
When E-mail Print Fails
Printing Files from the Printer Using FTP Client
Specifying a Password for a Document and Printing (Secured Print)
Attention (Specifying a Password for a Document and Printing (Secured Print))
Saving a Document in the SD Card in the Printer (Stored Job Print)
Performing a Stored Job Print Using the Control Panel of the Printer
Displaying or Operating the Jobs Stored in a Box (Resume/Delete)
Automatically Deleting Files Stored in a Box
Changing the Box Settings
Giving Priority to a Print Job (Interrupt Printing)
Top » Useful Printing Functions » Printing from a Computer (Windows) » Printing Fundamentals » Setting the Printer Options
08X4-0RU
Before printing, you need to set up the printer configuration in order to use the functions of printer options (such as paper feed options, paper output options, etc.) attached to and installed in the machine.
The printer configuration can be set up automatically while installing the driver. If the machine cannot be configured during the installation, follow the procedure below.
To configure the printer option settings, you must log on to your computer as a member of the Administrators.
Open the printer folder.
Right-click the icon of the printer whose settings you want to specify → click [Properties] (or [Printer properties]).
Click [Device Settings] → [Get Device Status].
4.
Confirm the settings such as paper source options and output options → click [OK].
If the information request returns an error message, you need to configure the settings (such as paper feed options, paper output options, etc.) manually.
If the printer and computer are connected via USB or a WSD (Web Services on Devices) port, the [Get Device Status] function is unavailable. You need to configure the settings manually.
