The environment in which this function is unavailable
You cannot use this function on the DOS application, UNIX or other computer on which the printer driver cannot be used. Print jobs are processed in the [Print] mode.
When the amount of data or number of jobs that you can save on the SD card exceeds the limit
The message <Cannot perform secured print.> appears. When the message is displayed, perform the following procedure.
When using the "Encrypted Secured Print" function whose security is reinforced for data communication and stored data
You need to install "Encrypted Secured Print Driver Add-in."
For details on the installation procedure, see "Readme.txt" in the supplied CD-ROM.
Timing to delete secured print jobs
Secured print jobs/encrypted secured print jobs are deleted in the following circumstances:
When the printer is turned OFF
When a hard reset or soft reset is performed
After a secured print job/encrypted secured print job is printed
When no printing operation has been performed by the printer's control panel or Remote UI for a fixed period
