e-ManualTopSite mapHelp
Chapter Top
Printing Fundamentals
Printing
Setting the Printer Options
Viewing the Online Help
Printing Functions
Common Functions
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
[Device Settings] Tab
Scaling Documents
1-sided Printing and 2-sided Printing
Attention (1-sided Printing and 2-sided Printing)
Booklet Printing
Poster Printing
Watermark Printing
Printing from a Computer (Macintosh)
Printing
Viewing the Driver Guide
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
Scaling Documents
1-sided and 2-sided Printing
Using [Presets] for Printing
Setting Priority (When Specifying the Same Item Using Multiple Methods)
Functions Which Can Be Specified from the Control Panel
Printing without the Printer Driver (Direct Print)
Printing the PDF File Using the Direct Print Function
Printing the PS/EPS File Using the Direct Print Function
Printing the TIFF/JPEG File Using the Direct Print Function
Printing the XPS File Using the Direct Print Function
Direct Printing from Command Prompt
Printing Files Directly from USB Memory Devices (USB Direct Print)
Printing Directly from USB Memory Device
Print Setting Menu List
Changing the Default Print Settings and File Sorting Criteria
Remove the USB Memory Device
Receiving E-mail Data on the Mail Server and Printing (E-mail Print)
How to Specify the Settings for E-mail Print
Attention (How to Specify the Settings for E-mail Print)
Receiving and Printing E-mails Manually
Printing the E-mail Receive Log List
Attention (Printing E-mail Sending/Receiving History)
When E-mail Print Fails
Printing Files from the Printer Using FTP Client
Specifying a Password for a Document and Printing (Secured Print)
Attention (Specifying a Password for a Document and Printing (Secured Print))
Saving a Document in the SD Card in the Printer (Stored Job Print)
Performing a Stored Job Print Using the Control Panel of the Printer
Displaying or Operating the Jobs Stored in a Box (Resume/Delete)
Automatically Deleting Files Stored in a Box
Changing the Box Settings
Giving Priority to a Print Job (Interrupt Printing)
Top » Useful Printing Functions » Saving a Document in the SD Card in the Printer (Stored Job Print)
08X4-070
You can save print jobs in the SD card (box) in the printer by selecting [Store] from the printer driver for this printer.
In addition, stored jobs can perform the following operations from the printer's control panel and the Remote UI.
You can print data by selecting the saved box or job.
You can check or operate the jobs stored in a box. You can perform operations of Resume (Print) and Delete. You can also check the jobs in detail. This operation is performed from the Remote UI.
You can change the name of the box in which data is saved or password. This operation is performed from the Remote UI.
About stored jobs
The stored jobs can be displayed or operated only when the SD card is installed, and [SD Card] is set to [On]. For details on the settings for [SD Card], see "[Setup] Menu ([Control Menu] Options)."
The saved jobs are saved on the SD card even after printing, and they are not deleted even after turning the printer OFF. When you want to delete the saved jobs, use the Remote UI.
Up to the total of 1000 jobs in all the boxes can be saved.
You can change the name of the stored job in the printer driver before printing.
Stored jobs can be deleted automatically by setting a length of time to pass between storing of the jobs and their deletion. On how to set the length of this time, see "Automatically Deleting Files Stored in a Box."
Since processing for deleting stored jobs is performed in background, the screen display does not always show the actual state depending on your system environment. For example, even if "0" is displayed as number of jobs stored in a box, you may not be able to store new jobs in the same box. In this case, wait for some time and then try again the job storing operation.
When the amount of data or number of jobs that you can save on the SD card exceeds the limit
The message <Cannot store.> is displayed. When the message is displayed, perform the following procedure.
(1)
Press [  ] (Online) to skip the error. (The job for which the error was skipped will be deleted.)
(2)
Delete any unnecessary jobs from among the jobs saved on the SD card.
(3)
Save the jobs again.
Operating the Remote UI
