08X4-0SW
If the machine is connected by unidirectional communication, you must set the printer options (such as paper feed options, paper output options, etc.) attached to and installed in the machine manually.
If the machine is connected by bidirectional communication, the settings for this procedure are disabled. Follow the procedure in " Verifying the Printer Information" to automatically set the options.
Open [System Preferences] → click [Print & Fax].
Select the printer you are using → click [Options & Supplies].
Click [Driver] → confirm that your printer is selected for [Print Using] → configure the options installed in the printer.
Be sure to select only those options that are actually installed in the printer.
4.
Click [OK].
