e-ManualTopSite mapHelp
Top » Basic Printer Operations » Paper Loading and Output
08X4-035
This printer has the following paper sources and output trays.
Paper Source
(A): Multi-purpose tray
(B): Drawer 1
(C): Drawer 2 (optional)
(D): Drawer 3 (optional)
Output Tray
(E): Output tray
Outputs paper with the printed side facing down.
(F): Sub-output tray
Outputs paper with the printed side facing up.
The sub-output tray is suitable to print transparencies, labels, or envelopes which tend to curl, since the printed paper is output flattened.
How to Switch Output Trays
When switching to the sub-output tray
(1)
Open the sub-output tray as shown in the figure.
(2)
Pull out the tray extension until it stops.
When switching to the output tray
(1)
Place the tray extension back into its original position as shown in the figure.
(2)
Close the sub-output tray.
Precautions for Output Trays
Pay attention to the following points when handling the output trays.
When performing 2-sided printing, close the sub-output tray.
(When outputting paper to the sub-output tray, you cannot perform 2-sided printing.)
During 2-sided printing, do not touch the paper until it is output to the output tray completely. The paper is first output partially after the front side is printed, and then it is fed again to be printed on the back side.
When printing on 16K paper, transparency or envelopes, output them to the sub-output tray. Outputting them to the output tray may cause paper jams.
When outputting long-size paper, such as Legal paper, to the output tray, open the auxiliary tray to prevent the paper from hanging out of the output tray.
Paper Capacity of the Paper Sources and Output Trays
: Unavailable
Paper Type
Paper Source
Output Tray*
Multi-purpose tray
Drawer 1
Drawer 2, 3
(optional)
Output tray
Sub-output tray
Plain paper (19.9 lb Bond (75 g/m²))
Approx. 100 sheets
Approx. 500 sheets
Approx. 500 sheets
Approx. 250 sheets
Approx. 50 sheets
Heavy paper (24.0 lb Bond (91 g/m²))
Approx. 80 sheets
Approx. 400 sheets
Approx. 400 sheets
Approx. 100 sheets
Approx. 50 sheets
Heavy paper (50.0 lb Cover (128 g/m²))
Approx. 50 sheets
Approx. 40 sheets
Approx. 30 sheets
Transparency
Approx. 50 sheets
Approx. 10 sheets
Label
Approx. 40 sheets
Approx. 60 sheets
Approx. 40 sheets
Index Card
Approx. 35 sheets
Approx. 35 sheets
Envelope
Approx. 10 sheets
Approx. 10 sheets
Actual paper capacity varies depending on the installation environment, paper type or paper size to be used.
