Before initiating the Initialize All Data/Settings mode, make sure that the data you are erasing is completely unnecessary. Note that Canon will not be liable for any damages resulting from the loss of data.
If the Copy Card Reader-F1 is attached to the machine, and does not operate properly after initializing the data, contact your local authorized Canon dealer.
To prevent other users from accidentally erasing all the data on the hard disk, it is recommended to register a System Manager ID and System PIN so that only the System Manager can perform this procedure.
Confirm that there are no current jobs being processed before using the Initialize All Data/Settings mode.
Backup or export any necessary data before erasing the data in the machine. You can backup or export the following data:
Data you can backup using the Remote UI
Mail box settings, stored files in the mail box, and registered forms for Superimpose Image (For information on backing up data, see "Backing Up Stored Data.") Data you can export using the Remote UI
(Depending on the MEAP application, you may be able to backup this data. For more information, see the manual for the MEAP application you are using.) License files for MEAP applications
(For information on downloading license files, see "Managing Application Licenses.") User authentication information registered in the Local Device Authentication system of SSO-H (Single Sign-On H)
(For information on exporting authentication information, see "Registering/Editing User Data for Local Device Authentication.") Settings which can be sent using the Device Information Delivery mode
(Can only be backed up if you have another machine with the Device Information Delivery mode. It is not necessary to back up this data if you want to use the data already registered in the other machine. For more information on the Device Information Delivery mode, see "Specifying Device Information Delivery Settings.") Data saved from MEAP applications
(Depending on the MEAP application, you may be able to back up this data. For more information, see the manual for the MEAP application you are using.) |
(Settings/Registration). |
[Once with 0 (Null) Data]:
Overwrite the data once with 0 (null) data.
[Once with Random Data]:
Overwrite the data once with random data.
[3 Times with Random Data]:
Overwrite the data three times with random data.
[9 Times with Random Data]:
Overwrite the data nine times with random data.
[DoD Standard]:
Overwrite the data three times. The first time is with a fixed value, the second time with a complement of the fixed value, and the third time is with random data.
If there are any current jobs being processed, they will be canceled, and then erased.
You cannot access the machine while the hard disk is being initialized.
The Initialize All Data/Settings mode does not delete any data the machine has stored on a server or computer.
For information on Initialize All Data/Settings Report, see "Initialize All Data/Settings Report."
