e-ManualTopSite mapHelp
Category Top
Preventing Unauthorized Access
Increasing Security
Restricting Access by Authentication
Administrator Settings
Specifying the System Manager Settings
Department ID Management
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
Accepting B&W Copy and Print Jobs without Entering a Department ID
User Setting Information Management (User Setting Information Management Service)
Logging In to the User Setting Information Management Service Page
Deleting the User Setting Information
Authentication Method Settings for Sending Operations
Specifying Personal Folders
Registering Personal Folders for Each User
Setting Up the Home Folder and Personal Folders
Registering Folders Designated by Login Service as Personal Folders
Specifying Authentication Method for LDAP Server
Specifying Authentication Method for Rights Management Server
Specifying Authentication Method for SMTP Server
Specifying Authentication Method for File Server
Simple Authentication Settings for Secure Print
Setting to Disable Integrated Authentication
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Using an Encryption Method That Complies with FIPS 140-2
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Confirming a Key Pair and User Certificate
Checking a Device Signature/User Signature Certificate
Setting a Rights Management Server
Copy Set Numbering Options
Accepting Only Encrypted Secure Printing
Restricting the Send Function
Setting the Address Book
Mail Box Settings
Specifying Settings for All Mail Boxes
Specifying the Mail Box Security Settings
Setting the Control Panel Display
Specifying Management Settings for the Hard Disk
Completely Erasing Unnecessary Data from the Hard Disk
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Delivery Settings
Registering/Deleting/Printing Delivery Destinations
Setting Automatic Delivery
Setting Manual Delivery
Setting the Receiving Machine
Checking/Printing the Communication Log
Setting SSO-H Authentication for Device Information Delivery Settings
Limiting Functions
Remote UI
Clearing the Message Board
ACCESS MANAGEMENT SYSTEM
Retrieving Audit Logs
Saving a Log of Key Operations
Available Administrator Settings Table (Touch Panel Display)
IEEE 2600 Security Standard
Top » Security » Authentication Method Settings for Sending Operations » Specifying Authentication Method for Rights Management Server
0L3X-24U
You can specify the authentication method for accessing a Rights Management server.
Select the authentication information used for accessing a Rights Management server.
Press [Function Settings] → [Common] → [Set Authentication Method] → [Info. Used for Rights Mgmt. Server Auth.].
Select information used for Rights Management server authentication.
Details of each item are shown below:
[Device Settings]:
Uses the authentication information set in [Rights Management Server Settings]. (See "Setting a Rights Management Server.") Further settings are not required for every user.
[Regist. Info. for Each User]:
Uses the authentication information registered by each user of a Rights Management server. Further settings are required for each user.
4.
Press [OK].
Settings for Each User
Log in to the machine.
Press (Main Menu) → [Scan and Send] → → [Register/Edit Information for Each User].
You can register user information from on [Scan and Send] Basic Features screen, [Access Stored Files] Send screen, and [Fax/I-Fax Inbox] Send screen.
Press [Rights Management Server Auth. Information].
4.
Enter the user name and password used for Rights Management Server authentication → press [OK].
