e-ManualTopSite mapHelp
Category Top
Preventing Unauthorized Access
Increasing Security
Restricting Access by Authentication
Administrator Settings
Specifying the System Manager Settings
Department ID Management
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
Accepting B&W Copy and Print Jobs without Entering a Department ID
User Setting Information Management (User Setting Information Management Service)
Logging In to the User Setting Information Management Service Page
Deleting the User Setting Information
Authentication Method Settings for Sending Operations
Specifying Personal Folders
Registering Personal Folders for Each User
Setting Up the Home Folder and Personal Folders
Registering Folders Designated by Login Service as Personal Folders
Specifying Authentication Method for LDAP Server
Specifying Authentication Method for Rights Management Server
Specifying Authentication Method for SMTP Server
Specifying Authentication Method for File Server
Simple Authentication Settings for Secure Print
Setting to Disable Integrated Authentication
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Using an Encryption Method That Complies with FIPS 140-2
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Confirming a Key Pair and User Certificate
Checking a Device Signature/User Signature Certificate
Setting a Rights Management Server
Copy Set Numbering Options
Accepting Only Encrypted Secure Printing
Restricting the Send Function
Setting the Address Book
Mail Box Settings
Specifying Settings for All Mail Boxes
Specifying the Mail Box Security Settings
Setting the Control Panel Display
Specifying Management Settings for the Hard Disk
Completely Erasing Unnecessary Data from the Hard Disk
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Delivery Settings
Registering/Deleting/Printing Delivery Destinations
Setting Automatic Delivery
Setting Manual Delivery
Setting the Receiving Machine
Checking/Printing the Communication Log
Setting SSO-H Authentication for Device Information Delivery Settings
Limiting Functions
Remote UI
Clearing the Message Board
ACCESS MANAGEMENT SYSTEM
Retrieving Audit Logs
Saving a Log of Key Operations
Available Administrator Settings Table (Touch Panel Display)
IEEE 2600 Security Standard
Top » Security » Available Administrator Settings Table (Touch Panel Display)
0L3X-26X
If the administrator is specified, you can restrict operations by general users and allow the administrator to set the settings of each function on Settings/Registration. The settings available for operation vary according to the type of administrator. This section describes the settings in Settings/Registration that each type of administrator can operate.
Preferences
If the administrator is specified, the following settings in [Preferences] can be set only by the administrator.
: Only the administrator can change the settings.
-: Depending on the type of the administrator when using the SSO-H, settings cannot be changed.
System Manager/System Administrator (Administrator)
Network Administrator (NetworkAdmin)
Device Administrator (DeviceAdmin)
[Paper Settings]
[Paper Type Management Settings]
[Display Settings]
[Default Screen after Startup/Restoration]
[Display Fax Function]
[Store Location Display Settings]
[ID/User Name Display On/Off]
[Display Remaining Toner Error Message]
[Edit Puncher Unit Die Name]
[Timer/Energy Settings]
[Date/Time Settings]
[Time Format]
[Quick Startup Settings for Main Power]
[Restrict Auto Reset Time]
[Network]
[Confirm Network Connection Set. Changes]
[TCP/IP Settings]
[NetWare Settings]
[AppleTalk Settings]
[SMB Server Settings]
[SNMP Settings]
[Dedicated Port Settings]
[Use Spool Function]
[Waiting Time for Connection at Startup]
[Ethernet Driver Settings]
[IEEE 802.1X Settings]
[Firewall Settings]
[IPv4 Address Filter]
[IPv6 Address Filter]
[MAC Address Filter]
[IP Address Block Log]
[External Interface]
[USB Settings]
[Extension Card Settings]
Adjustment/Maintenance
If the administrator is specified, the following settings in [Adjustment/Maintenance] can be set only by the administrator.
[Adjust Image Quality]
[Auto Adjust Gradation]
[Register Paper to Adjust]
[Select Paper to Adjust]
[Select Method]
[Number of Sheets to Output for Test Page]
[Adjustment Level]
[Auto Correct Color Tone Settings]
[Register Correction Pattern]
[Dither Settings]
[Color Balance]
[Correct Color Cast]
[Correct White Gap]
[Low Temperature Environment Mode]
[Correct Uneven Gloss]
[Adjust Drum Temperature]
[Special Smoothing]
[Gradation Adjustment During Printing]
[Adjust Action]
[Color/B&W Priority for First Print Time]
[Maintenance]
[Refresh Fixing Belt]
[Fixing Belt Auto Refresh Level]
Function Settings
If the administrator is specified, the following settings in [Function Settings] can be set only by the administrator.
[Common]
[Paper Output Settings]
[Normal/Rvrse. Order Output with Extrnl. Fin.]
[Face Up/Face Down Output with Extrnl. Fin.]
[Image Orient. When Output with Extrnl. Fin.]
[Print Settings]
[Copy Set Numbering Option Settings]
[Scan Settings]
[Auto Online]
[Auto Offline]
[Generate File]
[Rights Management Server Settings]
[Set Authentication Method]
[Copy]
[Select Color Settings for Copy]
[Printer]
[Restrict Printer Jobs]
[PDL Selection (Plug and Play)]
[Send]
[Common Settings]
[TX Report]
[Report with TX Image]
[Report with Color TX Image]
[Confirm SSL Certificate for WebDAV TX]
[Limit New Destination]
[Always Add Device Signature to Send]
[Limit E-Mail to Send to Myself]
[Restrict File TX to Personal Folder]
[Personal Folder Specification Method]
[Restrict Resending from Log]
[E-Mail/I-Fax Settings]
[Communication Settings]
[Confirm SSL Certificate for SMTP TX]
[Confirm SSL Certificate for POP RX]
[Maximum Data Size for Sending]
[Default Subject]
[Specify Authentication User Dest. to Reply]
[Set Authentication User Dest. to Sender]
[Allow Unregistered Users to Send E-Mail]
[Full Mode TX Timeout]
[Print MDN/DSN upon Receipt]
[Use Send via Server]
[Allow MDN Not via Server]
[Restrict TX Destination Domain]
[Auto Complete for Entering E-Mail Addresses]
[Fax Settings]
[Use Auth. User Name as Sender Name]
[Fax TX Report]
[PIN Code Access]
[Confirm Entered Fax Number]
[Restrict Seq. Broadcast When Fax Dest. Incl.]
[Remote Fax TX Settings]
[Receive/Forward]
[Common Settings]
[Interrupt and Print RX Jobs]
[Handle Files with Forwarding Errors]
[Forwarding Settings]
[Set Fax/I-Fax Inbox]
[Memory RX Inbox PIN]
[Use I-Fax Memory Lock]
[Memory Lock Start Time]
[Memory Lock End Time]
[Divided Data RX Timeout]
[Always Send Notice for RX Errors]
[Store/Access Files]
[Common Settings]
[Limit Box PIN to 7 Digits/Restrict Access]
[Mail Box Settings]
[Settings for All Mail Boxes]
[Box Security Settings]
[Memory Media Settings]
[Secure Print]
[Simple Authentication Settings]
[Only Allow Encrypted Print Jobs]
[Hold]
[Time Until Hold Job Auto Delete]
Destination Settings
If the administrator is specified, the following settings in [Set Destination] can be set only by the administrator.
[Address Book PIN]
[Manage Address Book Access Numbers]
[Include Pswd. When Exporting Address Book]
[Register LDAP Server]
[Auto Search When Using LDAP Server]
[Change Default LDAP Search Conditions]
[Register/Edit LDAP Search Conditions]
[Acquire Remote Address Book]
[Make Remote Add. Book Open]
Management Settings
If the administrator is specified, the following settings in [Management Settings] can be set only by the administrator.
[User Management]
[System Manager Information Settings]
[Department ID Management]
[Device Management]
[Device Information Settings]
[Device Information Distribution Settings]
[Limited Functions Mode]
[Certificate Settings]
[Display Job Status Before Authentication]
[Display Job Log]
[Save Audit Log]
[Store Key Operation Log]
[Format Encryption Method to FIPS 140-2]
[License/Other]
[Register License]
[MEAP Settings]
[Remote UI]
[Delete Message Board Contents]
[Remote Operation Settings]
[Use ACCESS MANAGEMENT SYSTEM]*
[Register/Update Software]
[Data Management]
[HDD Data Complete Deletion]
[Initialize All Data/Settings]
[TPM Settings]
Indicates item that appears only when ACCESS MANAGEMENT SYSTEM is activated. For information on the optional products required to use ACCESS MANAGEMENT SYSTEM, see "Optional Products Required for Each Function."
For information on the types of administrators, see "Administrator Settings."
