Category Top
Printing Functions
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
Common Functions
[Device Settings] Tab
System Requirements
Installation
Setting the Printer Options
Other Software Programs
Printing Fundamentals
Printing
Viewing the Online Help
Scaling Documents
1-sided and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
System Requirements
Installation
Printing
Scaling Documents
Setting Custom Paper Sizes
Booklet Printing
Using [Presets] for Printing
Personality
Menu Functions
Accessing the Settings Menu
Canceling Print Jobs
Report Settings
Copies
2-Sided Printing
Paper Feed
Print Quality
Layout
Auto Error Skip
Secure Print Delete Time
Timeout
Print After Completing RIP
Finishing
Punch
Booklet
Saddle Stitch
Creep Correction
Transparency Interleaving
Copy Set Numbering
Personality
Mode Priority
Color Mode
Gradation Settings
Compressed Image Output
Initialize
UFR II Settings
Halftones
RGB Source Profile
Output Profile
Matching Method
Gray Compensation
CMS (Matching) Selection
CMS (Matching)/Gamma
Gamma Correction
Paper Save
Advanced Smoothing
PCL Settings
Paper Save
Orientation
Font Number
Point Size
Pitch
Form Lines
Character Code
Custom Paper
Unit of Measure
X Dimension
Y Dimension
Append CR to LF
Enlarge A4 Print Width
Halftones
RGB Source Profile
Output Profile
Matching Method
Gray Compensation
Gamma Correction
Advanced Smoothing
PS Settings
Job Timeout
Print PS Errors
Pure Black Text
Black Overprint
Matching Mode
RGB Source Profile
CMYK Simulation Profile
Use Grayscale Profile
Output Profile
Matching Method
Device Link Profile
RGB Pure Black Process
CMYK Pure Black Process
Halftones
Brightness
Spot Color Matching
Composite Overprint
Advanced Smoothing
Grayscale Conversion
Imaging Settings
Image Orientation
Zoom Mode
Print Position
Show Warnings
Enlarge Print Area
Matching Mode
ICC Profile Settings
Kyuanos Set. (Color Only)
Photo Correct (Color Only)
Halftones
Gray Compensation
PDF Settings
Enlarge/Reduce to Fit Size
Enlarge Print Area
N on 1
Comment Print
Pure Black Text
Black Overprint
Matching Mode
RGB Source Profile
Output Profile
Matching Method
Device Link Profile
Halftones
Brightness
Spot Color Matching
Composite Overprint
Advanced Smoothing
XPS Settings
Matching Mode
Gamma Settings
Photo Correct.(Color Only)
Halftones
Gray Compensation
Advanced Smoothing
Utility Settings
Restricting Printer Jobs
PDL Selection (Plug-n-play)
Printing Problems
Some Basic Facts about Fonts
What Is a Font?
Attributes of Fonts
Fonts and Scalable Fonts
Typeface Samples
Symbol Sets 1
Symbol Sets 2
Symbol Sets 3
Symbol Sets 4
Symbol Sets 5
Configuration Page
Release Notes
Bar Code Printing
Introduction
Menus and Their Functions
Building/Printing a Bar Code
Control Codes
Font Parameters
Bar Code Format Parameters
Bar Code Usages and Formats
Troubleshooting
List of Error Messages
Printing Problems
Top » Print » Setting the Machine (PS/PCL/UFR II Printer) » Release Notes
Release Notes
06RH-1L9
Notes on using the NetWare print services banner page setting and page breaks in Windows applications
If a print job sent to the machine contains a banner page or page break command (referred to as a banner page below) the job is processed as two separate jobs. Therefore, you should remember the following points when using the banner page setting:
When the job is displayed on the machine's touch panel display or in the utility software, the main document and the banner page are displayed separately. If you cancel or change the print order of the main document, the banner page is still printed or mixed in with other print jobs unless it is also canceled or its order in the print queue is changed.
If several print jobs are sent to the machine at the same time, the banner page associated with the main document of a job may not printed immediately after the job, but in a different order.
If you are using the impression count setting for the Department ID Management function, the banner page is not counted as an impression. It is counted as a job with an unknown ID.
4.
Even if the main document is a secure print job, protected by a password, the banner page is not processed as a secure print job, and is printed immediately when it reaches the top of the print queue.
5.
If a print job is stored in an inbox, the banner page is not stored in the inbox and is printed.
6.
If a print job containing a banner page is printed using a driver that is not specific to this machine, the print job may not be executed correctly.
7.
In models that is equipped with a fax function, a banner page is not considered a fax transmission job even if the print job is set up as a fax transmission, and only the banner page is printed.
Notes on using the NetWare print services form feed function
Even if you have specified a form feed setting for a print job, a form feed is not performed. The form feed function is effective for only line printers. It is not necessary for page printers. If the form feed function is enabled, the form feed may be inserted in an unexpected location, and the print result may be incorrect.
Notes on using the PS print functions
Limitation when using the Group function when sending a print job to an inbox
If you specify multiple copies when sending a print job to an inbox that uses the Group function, the copy quantity when you print from the inbox is one rather than the actual number of copies specified for the job. However, when you print the job, the number of copies specified when the job was sent to the inbox are printed. This means that if you specify more than one copy when printing from the inbox, the machine prints the multiple copy job several times. Unnecessary copies of the job are printed if you specify several copies when printing because only 1 was displayed for the copy quantity when printing from the inbox.
Limitations on setting the number of copies to '0'
If a job is complex, pages may be printed even when you set the copy quantity to '0'. If this happens, try using the PCL5 printer driver and using the Graphics mode.
Limitations when printing from Macintosh computers
If you specify the Gutter Location, when printing with the 2 in 1 (L→R) layout, the job is printed with the gutter shifted in the opposite direction.
