[sRGB], [NTSC]*, [Uniform RGB]
You can select ways to convert color values to a grayscale value when you print color print data.
Lets you to calculate the grayscale value by the color conversion method based on sRGB.
Lets you to calculate the grayscale value by the color conversion method based on NTSC.
Counts the average value of the Red, Green, and Blue values as the grayscale value.
This section describes the settings to convert the color data into grayscale data.
This setting is invalid for black-and-white data.
If the color mode is set to [Auto (Color/B&W)] or [Color], this setting is invalid.
