[Cyan]
-8 to +8; 0*
[Magenta]
-8 to +8; 0*
[Yellow]
-8 to +8; 0*
[Black]
-8 to +8; 0*
[Cyan]
[High]
-8 to +8; 0*
[Medium]
-8 to +8; 0*
[Low]
-8 to +8; 0*
[Magenta]
[High]
-8 to +8; 0*
[Medium]
-8 to +8; 0*
[Low]
-8 to +8; 0*
[Yellow]
[High]
-8 to +8; 0*
[Medium]
-8 to +8; 0*
[Low]
-8 to +8; 0*
[Black]
[High]
-8 to +8; 0*
[Medium]
-8 to +8; 0*
[Low]
-8 to +8; 0*
This setting cannot be applied to jobs in PCL5c mode.
This setting is only available if 'Resolution' is set to [1200 dpi].
If you select [1200 dpi] for [Resolution], you cannot specify the following settings: rotate collate, different paper sizes (LTR/LGL), and double stapling on the short edge of A4 and LTR size paper.
For all selections within this setting, if the data is too large to be stored in the machine's memory, it will be recompressed at a high compression ratio.
To avoid deterioration in image quality resulting from repeated recompression, select [Display Error] for "Compressed Image Output." This allows you to cancel a job before an image with deterioration is printed out.
Depending on the image data, the image quality may not change even if the compression mode is changed.
[Trapping]
[On], [Off]*
[Trapping Width]
1 to 3; 1* pixel
[Trapping Density]
25 to 100; 100* %
The internal restriction value cannot be changed.
This setting can only be applied to jobs in the PS mode and PDF mode.
If [Gradation] is selected, characters and lines may bleed.
If [Text] is selected, the color may not match.
This setting can only be applied to jobs in the UFR II mode, PCL6 mode, PS mode, PDF mode, and XPS mode.
