: Available - : Unavailable
No Options
Inner 2 Way Tray-F1, Copy Tray-J1
Inner Finisher-E1
Staple Finisher-J1, Booklet Finisher-J1
Collate
Rotate+Collate
Rotate+Group
Offset+Collate
Offset+Group
Staple+Collate
Staple+Group
A large print job may be automatically canceled by the machine. The maximum number of pages that can be printed at one time is approximately 6,000 pages. However, this number may be fewer than 6,000 if other functions (such as registering a form) are in use, or other jobs are being processed.
[Rotate+Collate] and [Rotate+Group] are available if the paper size is LTR, LTRR, A4, A4R, B5, or B5R.
If you select [Rotate+Collate] or [Rotate+Group], part of the print image may be cut off when the image is rotated. You need to load the same size paper as the original in the paper drawers in both landscape and portrait positions. If you do not, all the sheets will be printed in the orientation that the loaded paper is in.
[Offset+Collate] and [Offset+Group] are available if you select the following paper size:
When the Inner Finisher-E1 is attached: 11" × 17", LGL, LTR, LTRR, STMT, EXEC, A3, A4, A4R, A5, B4 or B5
When the Staple Finisher-J1 or the Booklet Finisher-J1 is attached: 11" × 17", LGL, LTR, LTRR, EXEC, A3, A4, A4R, B4 or B5
When you are stapling paper in landscape orientation, the image orientation and the staple position may not match.
Corner (Upper-Left)
Double (Top)
Corner (Upper-Right)
Double (Right)
Corner (Lower-Right)
Double (Bottom)
Corner (Lower-Left)
Double (Left)
11" x 17"
LGL
LTR
LTRR
EXEC
A3
B4
A4
A4R
B5
Corner (Upper-Left)
Double (Top)
Double (Right)
Double (Bottom)
Corner (Lower-Left)
Double (Left)
11" x 17"
LGL
LTR
LTRR
A3
B4
A4
A4R
B5
EXEC
For the Staple Finisher-J1 and Booklet Finisher-J1, the maximum number of sheets of thin or plain type paper that can be stapled at one time is:
A3, B4, A4R, 11” x 17”, LGL, LTRR: 30 sheets
A4, B5, LTR, EXEC: 50 sheets
For the Inner Finisher-E1, the maximum number of sheets of thin or plain type paper that can be stapled at one time is:
Make sure to select compatible settings when using Staple and Punch simultaneously. If conflicting settings are selected, such as the staple setting for the right side of the paper and the punch setting for the left, the printer will use neither Staple nor Punch.
