Category Top
Printing Functions
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
Common Functions
[Device Settings] Tab
System Requirements
Installation
Setting the Printer Options
Other Software Programs
Printing Fundamentals
Printing
Viewing the Online Help
Scaling Documents
1-sided and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
System Requirements
Installation
Printing
Scaling Documents
Setting Custom Paper Sizes
Booklet Printing
Using [Presets] for Printing
Personality
Menu Functions
Accessing the Settings Menu
Canceling Print Jobs
Report Settings
Copies
2-Sided Printing
Paper Feed
Print Quality
Layout
Auto Error Skip
Secure Print Delete Time
Timeout
Print After Completing RIP
Finishing
Punch
Booklet
Saddle Stitch
Creep Correction
Transparency Interleaving
Copy Set Numbering
Personality
Mode Priority
Color Mode
Gradation Settings
Compressed Image Output
Initialize
UFR II Settings
Halftones
RGB Source Profile
Output Profile
Matching Method
Gray Compensation
CMS (Matching) Selection
CMS (Matching)/Gamma
Gamma Correction
Paper Save
Advanced Smoothing
PCL Settings
Paper Save
Orientation
Font Number
Point Size
Pitch
Form Lines
Character Code
Custom Paper
Unit of Measure
X Dimension
Y Dimension
Append CR to LF
Enlarge A4 Print Width
Halftones
RGB Source Profile
Output Profile
Matching Method
Gray Compensation
Gamma Correction
Advanced Smoothing
PS Settings
Job Timeout
Print PS Errors
Pure Black Text
Black Overprint
Matching Mode
RGB Source Profile
CMYK Simulation Profile
Use Grayscale Profile
Output Profile
Matching Method
Device Link Profile
RGB Pure Black Process
CMYK Pure Black Process
Halftones
Brightness
Spot Color Matching
Composite Overprint
Advanced Smoothing
Grayscale Conversion
Imaging Settings
Image Orientation
Zoom Mode
Print Position
Show Warnings
Enlarge Print Area
Matching Mode
ICC Profile Settings
Kyuanos Set. (Color Only)
Photo Correct (Color Only)
Halftones
Gray Compensation
PDF Settings
Enlarge/Reduce to Fit Size
Enlarge Print Area
N on 1
Comment Print
Pure Black Text
Black Overprint
Matching Mode
RGB Source Profile
Output Profile
Matching Method
Device Link Profile
Halftones
Brightness
Spot Color Matching
Composite Overprint
Advanced Smoothing
XPS Settings
Matching Mode
Gamma Settings
Photo Correct.(Color Only)
Halftones
Gray Compensation
Advanced Smoothing
Utility Settings
Restricting Printer Jobs
PDL Selection (Plug-n-play)
Printing Problems
Some Basic Facts about Fonts
What Is a Font?
Attributes of Fonts
Fonts and Scalable Fonts
Typeface Samples
Symbol Sets 1
Symbol Sets 2
Symbol Sets 3
Symbol Sets 4
Symbol Sets 5
Configuration Page
Release Notes
Bar Code Printing
Introduction
Menus and Their Functions
Building/Printing a Bar Code
Control Codes
Font Parameters
Bar Code Format Parameters
Bar Code Usages and Formats
Troubleshooting
List of Error Messages
Printing Problems
Top » Print » Setting the Machine (PS/PCL/UFR II Printer) » PS Settings » Device Link Profile
Device Link Profile
06RH-1H9
RGB Input (Light+ClrSpace)
[D50 + sRGB]*, [D65 + sRGB], [D50 + Adobe RGB], [D65 + Adobe RGB], [Profile Name]
This setting enables you to perform color matching by specifying the RGB input device link profile setting for RGB input data.
[D50 + sRGB]
Performs color matching to match the conditions of ambient light D50 (5,000 K) on an sRGB compatible monitor.
[D65 + sRGB]
Performs color matching to match the conditions of ambient light D65 (6,500 K) on an sRGB compatible monitor.
[D50 + Adobe RGB]
Performs color matching to match the conditions of ambient light D50 (5,000K) on an Adobe RGB compatible monitor.
[D65 + Adobe RGB]
Performs color matching to match the conditions of ambient light D65 (6,500K) on an Adobe RGB compatible monitor.
[Profile Name]
You can specify a profile name by selecting a downloaded Device Link Profile on the machine.
CMYK Input (Light+ClrSpace)
[D50 + JapanColor]*, [Profile Name]
This setting enables you to perform color matching that supports device link profile, for CMYK data.
[D50 + JapanColor]
Performs color matching to match the conditions for JapanColor by using ambient light D50 (5,000K).
[Profile Name]
If the color mode is set to [Black & White], the device link profile setting is invalid.
This setting can be specified only if [D. Link Profile] is selected in [RGB Input] in [Matching Mode].
The Device Link Profile is not applied to Device Grey, CIE Based ABC, CIE Based DEF, CIE Based DEFG, or CIE Based A. Even if the Device Link Profile is specified, regular processing is applied for the ICC Profile.
