Category Top
Printing Functions
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
Common Functions
[Device Settings] Tab
System Requirements
Installation
Setting the Printer Options
Other Software Programs
Printing Fundamentals
Printing
Viewing the Online Help
Scaling Documents
1-sided and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
System Requirements
Installation
Printing
Scaling Documents
Setting Custom Paper Sizes
Booklet Printing
Using [Presets] for Printing
Personality
Menu Functions
Accessing the Settings Menu
Canceling Print Jobs
Report Settings
Copies
2-Sided Printing
Paper Feed
Print Quality
Layout
Auto Error Skip
Secure Print Delete Time
Timeout
Print After Completing RIP
Finishing
Punch
Booklet
Saddle Stitch
Creep Correction
Transparency Interleaving
Copy Set Numbering
Personality
Mode Priority
Color Mode
Gradation Settings
Compressed Image Output
Initialize
UFR II Settings
Halftones
RGB Source Profile
Output Profile
Matching Method
Gray Compensation
CMS (Matching) Selection
CMS (Matching)/Gamma
Gamma Correction
Paper Save
Advanced Smoothing
PCL Settings
Paper Save
Orientation
Font Number
Point Size
Pitch
Form Lines
Character Code
Custom Paper
Unit of Measure
X Dimension
Y Dimension
Append CR to LF
Enlarge A4 Print Width
Halftones
RGB Source Profile
Output Profile
Matching Method
Gray Compensation
Gamma Correction
Advanced Smoothing
PS Settings
Job Timeout
Print PS Errors
Pure Black Text
Black Overprint
Matching Mode
RGB Source Profile
CMYK Simulation Profile
Use Grayscale Profile
Output Profile
Matching Method
Device Link Profile
RGB Pure Black Process
CMYK Pure Black Process
Halftones
Brightness
Spot Color Matching
Composite Overprint
Advanced Smoothing
Grayscale Conversion
Imaging Settings
Image Orientation
Zoom Mode
Print Position
Show Warnings
Enlarge Print Area
Matching Mode
ICC Profile Settings
Kyuanos Set. (Color Only)
Photo Correct (Color Only)
Halftones
Gray Compensation
PDF Settings
Enlarge/Reduce to Fit Size
Enlarge Print Area
N on 1
Comment Print
Pure Black Text
Black Overprint
Matching Mode
RGB Source Profile
Output Profile
Matching Method
Device Link Profile
Halftones
Brightness
Spot Color Matching
Composite Overprint
Advanced Smoothing
XPS Settings
Matching Mode
Gamma Settings
Photo Correct.(Color Only)
Halftones
Gray Compensation
Advanced Smoothing
Utility Settings
Restricting Printer Jobs
PDL Selection (Plug-n-play)
Printing Problems
Some Basic Facts about Fonts
What Is a Font?
Attributes of Fonts
Fonts and Scalable Fonts
Typeface Samples
Symbol Sets 1
Symbol Sets 2
Symbol Sets 3
Symbol Sets 4
Symbol Sets 5
Configuration Page
Release Notes
Bar Code Printing
Introduction
Menus and Their Functions
Building/Printing a Bar Code
Control Codes
Font Parameters
Bar Code Format Parameters
Bar Code Usages and Formats
Troubleshooting
List of Error Messages
Printing Problems
Top » Print » Setting the Machine (PS/PCL/UFR II Printer) » Settings Menu (Common Settings) » Copy Set Numbering
Copy Set Numbering
06RH-1E5
Copy Set Numbering
[On], [Off]*
This setting enables you to print documents with a five digit serial number in the background on each copy.
Copy numbers are printed in the following methods:
When printing three copies of a five page document:
Print Position
[5 Locations]*, [Top Left], [Bottom Left], [Top Right], [Bottom Right], [Full Surface]
This setting enables you to specify the position of the copy numbers to be printed. You can select to print numbers in all five positions, in each corner, or over the entire page.
Starting Number
1 to 9999; 1*
The Starting Number mode enables you to specify the copy number to start numbering. The default is '1' (printed as 00001), but you can specify up to '9999' (printed as 09999).
Number Size
[Small(12 point)], [Medium(24 point)], [Large(36 point)]*
The Number Size mode enables you to select the size of copy number from [Small(12 point)], [Medium(24 point)], and [Large(36 point)] ('12.0 pt.', '24.0 pt.', and '36.0 pt.').
Density
1 to 5; 3*
This setting enables you to adjust the number density and has 5 levels you can adjust, with level '3' (middle level) being the default setting. Selecting '1' makes the number lighter, and selecting '5' makes it darker.
Color
[Yellow], [Magenta], [Cyan], [Black]*, [Red], [Green], [Blue]
This setting enables you to specify the color of the copy number.
Number Position Vertical/Number Position Horizontal
-5/16 inches to +5/16 inches; 0* inches
The position of the copy numbers specified with the Print Position mode can be finely adjusted by offsetting them in the horizontal or vertical directions. The adjustment can be made in increments of 1/16" from -5/16" through +5/16".
You can increase or decrease the setting value to adjust the print position of the copy numbers, as described below.
[Number Position Vertical]
Increasing the setting value moves the print position in the downward direction of the paper. Decreasing the setting value moves the print position in the upward direction of the paper.
[Number Position Horizontal]
Increasing the setting value moves the print position to the right. Decreasing the setting value moves the print position to the left.
If the Copy Set Numbering mode is used in combination with [Printer Driver Secure Watermark] in [Function Settings] (Settings/Registration), this setting is invalid. For details on Printer Driver Secure Watermark, see "Security."
If the Finishing mode is specified as [Rotate+Group], [Offset+Group], or [Staple+Group], [Rotate+Collate], [Offset+Collate], or [Staple+Collate] is specified.
Please note that if the print position is adjusted to place the digits of the copy numbers outside the printable area, the portion outside the printable area is not printed.
If the copy number has fewer than five digits, the machine prints it as follows:
Example: If the copy number is 10
10→00010
Copy numbers are not printed on blank pages (pages with no data).
If the Copy Set Numbering mode is used in combination with the Gutter mode or Offset Short Edge/Offset Long Edge mode, part of the copy number may be cut off.
The Copy Set Numbering mode is not available if the Transparency Interleaving mode is enabled.
If the number of printed copies exceeds '99999', it returns to '00001'.
The Number Position Vertical/Number Position Horizontal mode is only effective for the print position of copy numbers. When adjusting print position (other than the copy numbers), perform the setting with the Offset Short Edge/Offset Long Edge mode. (See "Offset Short Edge/Offset Long Edge (Front)" and "Offset Short Edge/Offset Long Edge (Back).")
The Print Position mode is only available if you set [Copy Set Numbering] to [On].
The Starting Number mode is available only if you set [Copy Set Numbering] to [On].
The Number Size mode is only available if you set [Copy Set Numbering] to [On].
The Density mode is only available if you set [Copy Set Numbering] to [On].
The Color mode is only available if you [Copy Set Numbering] to [On].
The Number Position Vertical/Number Position Horizontal mode is only available if you set [Copy Set Numbering] to [On].
