Category Top
Printing Functions
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
Common Functions
[Device Settings] Tab
System Requirements
Installation
Setting the Printer Options
Other Software Programs
Printing Fundamentals
Printing
Viewing the Online Help
Scaling Documents
1-sided and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
System Requirements
Installation
Printing
Scaling Documents
Setting Custom Paper Sizes
Booklet Printing
Using [Presets] for Printing
Personality
Menu Functions
Accessing the Settings Menu
Canceling Print Jobs
Report Settings
Copies
2-Sided Printing
Paper Feed
Print Quality
Layout
Auto Error Skip
Secure Print Delete Time
Timeout
Print After Completing RIP
Finishing
Punch
Booklet
Saddle Stitch
Creep Correction
Transparency Interleaving
Copy Set Numbering
Personality
Mode Priority
Color Mode
Gradation Settings
Compressed Image Output
Initialize
UFR II Settings
Halftones
RGB Source Profile
Output Profile
Matching Method
Gray Compensation
CMS (Matching) Selection
CMS (Matching)/Gamma
Gamma Correction
Paper Save
Advanced Smoothing
PCL Settings
Paper Save
Orientation
Font Number
Point Size
Pitch
Form Lines
Character Code
Custom Paper
Unit of Measure
X Dimension
Y Dimension
Append CR to LF
Enlarge A4 Print Width
Halftones
RGB Source Profile
Output Profile
Matching Method
Gray Compensation
Gamma Correction
Advanced Smoothing
PS Settings
Job Timeout
Print PS Errors
Pure Black Text
Black Overprint
Matching Mode
RGB Source Profile
CMYK Simulation Profile
Use Grayscale Profile
Output Profile
Matching Method
Device Link Profile
RGB Pure Black Process
CMYK Pure Black Process
Halftones
Brightness
Spot Color Matching
Composite Overprint
Advanced Smoothing
Grayscale Conversion
Imaging Settings
Image Orientation
Zoom Mode
Print Position
Show Warnings
Enlarge Print Area
Matching Mode
ICC Profile Settings
Kyuanos Set. (Color Only)
Photo Correct (Color Only)
Halftones
Gray Compensation
PDF Settings
Enlarge/Reduce to Fit Size
Enlarge Print Area
N on 1
Comment Print
Pure Black Text
Black Overprint
Matching Mode
RGB Source Profile
Output Profile
Matching Method
Device Link Profile
Halftones
Brightness
Spot Color Matching
Composite Overprint
Advanced Smoothing
XPS Settings
Matching Mode
Gamma Settings
Photo Correct.(Color Only)
Halftones
Gray Compensation
Advanced Smoothing
Utility Settings
Restricting Printer Jobs
PDL Selection (Plug-n-play)
Printing Problems
Some Basic Facts about Fonts
What Is a Font?
Attributes of Fonts
Fonts and Scalable Fonts
Typeface Samples
Symbol Sets 1
Symbol Sets 2
Symbol Sets 3
Symbol Sets 4
Symbol Sets 5
Configuration Page
Release Notes
Bar Code Printing
Introduction
Menus and Their Functions
Building/Printing a Bar Code
Control Codes
Font Parameters
Bar Code Format Parameters
Bar Code Usages and Formats
Troubleshooting
List of Error Messages
Printing Problems
Top » Print » Setting the Machine (PS/PCL/UFR II Printer) » Menu Functions
Menu Functions
06RH-1C9
Specifying the Menu Settings
The machine lets you specify settings, such as the number of copies and the paper size, to use when it receives a print job. These types of settings can be specified by the application sending the print job, or by the printer driver.
You can specify many settings which affect the printer function of the machine. These include some settings that cannot be specified remotely from an application or from the printer driver. These settings are referred to as Menu Functions.
The menu functions are grouped together according to the type of settings, which makes them easy to set.
There are two ways you can specify the menu functions.
Specifying the settings on the touch panel display:
Display the Printer Settings screen on the touch panel display and specify the settings by pressing the keys on it.
Specifying the settings on the Remote UI:
You can specify some settings from your computer using your web browser.
Settings Priorities
When the same menu function setting can be specified by using the keys on the machine or by specifying the setting in an application or the printer driver, the setting from the application or printer driver has priority.
These settings will override the settings made on the machine.
The most recently specified settings take priority for settings available only on the touch panel display or Remote UI.
You can obtain the printer driver from the CD-ROM or the Canon Web site. For instructions on installing the printer driver, see the Driver Installation Guide.
Menus for Printer Settings
Printer Settings are configured with the menus below.
Printer Settings
Enables you to specify or change settings for printing from the machine.
The following menus are included within the Printer Settings menu.
Settings Menu
Enables you to specify or change settings common to all printer functions.
UFR II/PCL/PS Settings Menus
Enables you to specify or change settings for the operating mode when a UFR II/PCL/PS control command is received.
Imaging/PDF/XPS Settings Menus
Enables you to specify or change settings for the operating mode when Direct Print data is received.
Utility Settings
To initialize PCL or PS hard disk partition using "Initialize PCL Hard Disk" or "Initialize PS Hard Disk." (PCL or PS Printer only)
To reset the printer's print functions using "Reset Printer."
For instructions on specifying the menu settings on the Remote UI, please refer to "Remote UI."
The contents of the Printer Settings are stored in the nonvolatile memory of the machine. This means that the settings are stored even if the power to the machine is switched OFF, and therefore the settings will still be available when the power is switched ON again.
