Category Top
Printing Functions
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
Common Functions
[Device Settings] Tab
System Requirements
Installation
Setting the Printer Options
Other Software Programs
Printing Fundamentals
Printing
Viewing the Online Help
Scaling Documents
1-sided and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
System Requirements
Installation
Printing
Scaling Documents
Setting Custom Paper Sizes
Booklet Printing
Using [Presets] for Printing
Personality
Menu Functions
Accessing the Settings Menu
Canceling Print Jobs
Report Settings
Copies
2-Sided Printing
Paper Feed
Print Quality
Layout
Auto Error Skip
Secure Print Delete Time
Timeout
Print After Completing RIP
Finishing
Punch
Booklet
Saddle Stitch
Creep Correction
Transparency Interleaving
Copy Set Numbering
Personality
Mode Priority
Color Mode
Gradation Settings
Compressed Image Output
Initialize
UFR II Settings
Halftones
RGB Source Profile
Output Profile
Matching Method
Gray Compensation
CMS (Matching) Selection
CMS (Matching)/Gamma
Gamma Correction
Paper Save
Advanced Smoothing
PCL Settings
Paper Save
Orientation
Font Number
Point Size
Pitch
Form Lines
Character Code
Custom Paper
Unit of Measure
X Dimension
Y Dimension
Append CR to LF
Enlarge A4 Print Width
Halftones
RGB Source Profile
Output Profile
Matching Method
Gray Compensation
Gamma Correction
Advanced Smoothing
PS Settings
Job Timeout
Print PS Errors
Pure Black Text
Black Overprint
Matching Mode
RGB Source Profile
CMYK Simulation Profile
Use Grayscale Profile
Output Profile
Matching Method
Device Link Profile
RGB Pure Black Process
CMYK Pure Black Process
Halftones
Brightness
Spot Color Matching
Composite Overprint
Advanced Smoothing
Grayscale Conversion
Imaging Settings
Image Orientation
Zoom Mode
Print Position
Show Warnings
Enlarge Print Area
Matching Mode
ICC Profile Settings
Kyuanos Set. (Color Only)
Photo Correct (Color Only)
Halftones
Gray Compensation
PDF Settings
Enlarge/Reduce to Fit Size
Enlarge Print Area
N on 1
Comment Print
Pure Black Text
Black Overprint
Matching Mode
RGB Source Profile
Output Profile
Matching Method
Device Link Profile
Halftones
Brightness
Spot Color Matching
Composite Overprint
Advanced Smoothing
XPS Settings
Matching Mode
Gamma Settings
Photo Correct.(Color Only)
Halftones
Gray Compensation
Advanced Smoothing
Utility Settings
Restricting Printer Jobs
PDL Selection (Plug-n-play)
Printing Problems
Some Basic Facts about Fonts
What Is a Font?
Attributes of Fonts
Fonts and Scalable Fonts
Typeface Samples
Symbol Sets 1
Symbol Sets 2
Symbol Sets 3
Symbol Sets 4
Symbol Sets 5
Configuration Page
Release Notes
Bar Code Printing
Introduction
Menus and Their Functions
Building/Printing a Bar Code
Control Codes
Font Parameters
Bar Code Format Parameters
Bar Code Usages and Formats
Troubleshooting
List of Error Messages
Printing Problems
Top » Print » Setting the Machine (PS/PCL/UFR II Printer) » XPS Settings » Photo Correct.(Color Only)
06RH-1KA
Photo Optimizer PRO
[On], [Off]*
You can adjust the contrast, color balance, saturation, and balance for images.
[On]
Photo Optimizer PRO is performed on the image.
[Off]
The machine will not perform Photo Optimizer PRO.
Red-Eye Correction
[Red-Eye Correction]: [On], [Off]*
[Red-Eye Correction Level]: [Weak], [Standard]*, [Strong]
Detects and corrects red-eyes on photographs occurred because of the flash or electronic flash when photographing. You can also make corrections when only half of the face is shown on the photograph.
You can specify the settings for each type of data: [Red-Eye Correction] and [Red-Eye Correction Level].
[On]
Red-eye correction is performed on the image.
[Off]
Red-eye correction is not performed.
[Weak]
Correction level is small.
[Standard]
Correction level is between 'Weak' and 'Strong'.
[Strong]
Correction level is big.
Face Brightener
[Face Brightener]: [On], [Off]*
[Face Brightener Level]: [Weak], [Standard]*, [Strong]
If faces in the photographs appear dark because of backlight or underexposure, you can correct the brightness of the entire image to obtain the desired brightness for faces.
You can specify the settings for each type of data: [Face Brightener] and [Face Brightener Level].
[On]
Face Brightener is performed on the image.
[Off]
Face Brightener is not performed.
[Weak]
[Standard]
[Strong]
These settings are valid only when "Matching Mode" is set to [ICC Profile] or [Gamma].
These settings are invalid for black-and-white data.
If the color mode is set to [Black & White], these settings are invalid.
To activate the settings for "Red-Eye Correction Level", set "Red-Eye Correction" to [On].
The effect of the Red Eye Correction differs, depending on the data.
To activate the settings for "Face Brightener Level", set "Face Brightener" to [On].
The effect of the Face Brightener differs, depending on the data.
The Photo Optimizer Pro is not performed in the following cases:
When the number of pixels in the image is less than 400.
When the histogram of the image is biased.
When Photo Optimizer Pro detects that the adjustment is not necessary for the image.
The effect of the Photo Optimizer Pro differs, depending on the data. Desirable results may not be obtained especially for the divided image.
