06RH-1K1
[On], [Off]*
This setting enables you to specify the optimal method for reproducing spot colors. By using a named color profile, you can convert the color to one similar to the spot color and perform printing.
Spot color matching is performed.
Spot color matching is not performed.
Even if spot color matching is set to 'On', when a specified spot color name cannot be found, a substitute color (CMYK) is used for the printout.
